Issue with printing, sliced with Cura
jsrfo
3D Printer(s): Sovol SV01
Post by jsrfo »
Having issues printing this model sliced with Cura. At the level the three holes, there is thinning between the holes.
Can't figure it our after trying different retraction, combing, and Z Hop settings.
Re: Issue with printing, sliced with Cura
This is quite a frequent problem with Cura and happens quite often.
when any change happens on Z-Axis, could be many changes to the shape of the model, the outcome is always the same style texture surface change.
Look at this example
jsrfo
Post by jsrfo »
So, is there a resolution for this type of issue? I've been trying for months to resolve it, and nothing seems to work.
4.9 Beta just came out....worth a try?
Do not know if this is a solution or not, here goes.
I have printed most recent models with PrusaSlicer 2.3.0 it is more complex to setup though the printed model show results.
I still use Cura for other models that need less perfection.
There's also the Cura Users group on Facebook you could ask
Return to “Cura”
