Page 5 of 8
Re: Simplify3d basic guide
Posted: August 22nd, 2016, 12:00 pm
Just thinking out loud....do they have the means to import a printer profile from Cura? (Does Cura have one to export?)
Posted: August 22nd, 2016, 12:31 pm
No, it's not posible since old Cura doesn't have a gazillion options that s3d has
Posted: August 22nd, 2016, 3:03 pm
by reibuehl
Do they have a process to contribute such profiles like the one you created to fix the crappy defaults they ship?
Posted: August 22nd, 2016, 3:10 pm
I don't think so. All the support I got at the beginning from them was horrible and full or stupid answers. I hate their support. They even banned a post on their forum I made listing all the placeholders for the scripting
Posted: September 22nd, 2016, 2:40 am
by MTVDNA
I pulled the trigger today and bought S3D. The first time I tried to print something went horribly wrong for some reason I still don't understand. As soon as I started the print, first the extruder motor made a lot of noise (skipped steps), then the bed homed and then continued to move further down (causing the z motor some anguish), then when it raised the bed it crashed into the printhead.
Second attempt was better, even though I didn't really change any settings related to that. Only retractions were extremely slow. Apparently speeds in S3D are given in mm/min instead of per second. Third attempt is running now, and so far it's looking okay.
I just made some more adjustments to the startup script, because it still crashed into the bed clips. And I adjusted it to move the head into position before heating the bed and nozzle, like the default with cura. Also, for some reason X0 Y0 is in the back left instead of the front left, though that doesn't really matter much.
Edit:
It appears S3D doesn't use the G10 and G11 for retract and unretract. This is unfortunate because then you can't change retraction settings mid print. Has anybody here got that working?
Posted: September 22nd, 2016, 3:35 am
First. Preferences, there change the mm/m to mm/s
Second basic s3d profile sucks
Starting gcode, check the one Rigs use on his um2
https://ultimaker.com/en/community/1725 ... simplify3d
After all that, read all the pages of this post (it will help you get an idea of how to setup it.
My profile posted on the first page has a different gcode start that will make hotend hit the bedclips on um2.
Also, remove all auto crap asap and open advanced mode asap.
After all that we can start to tune your settings
Posted: September 22nd, 2016, 3:48 am
About retraction, google 2mins
Code: Select all
https://plus.google.com/+WalterHsiao/posts/Ri74TFzs4Ap
You can make a replace script to replace the retractions to the g10 g11. Ofc you first must make the speed and amount fixed so the replace can find exactly the data it searchs.
Edit. Poated link as code as I can't post the link directly
Posted: September 22nd, 2016, 3:53 am
Anyway... How can a um2 do retraction while wiping if is limited to that gcodes???
Posted: September 22nd, 2016, 7:49 am
by MTVDNA
Neotko wrote:Also, remove all auto crap asap and open advanced mode asap.
That's literally the first thing I did
I've read through this thread before I bought S3D, watched a bunch of tutorials on youtube also, so I know at least a little bit what I'm doing. Good point on the wiping retraction. That can't be done using G10/G11. I will just leave it for now, once I've found the correct retraction settings I won't need to adjust them mid print anyways.
I tried to use
this post from S3D to make my own starting script. For some reason the code they show there doesn't fully work.
Code: Select all
G28 ; home all axes
G1 X25 Y25 T0 F6000 ; bring extruder to front
M140 S[bed0_temperature] ; set bed temperature
M190 S[bed0_temperature] ; wait till bed temperature is stabilized
M104 S[extruder0_temperature] T0; set extruder temperature
M109 S[extruder0_temperature] T0; wait till extruder temperature is stabilized
G1 Z30 ; raise the bed
G92 E0 ; zero the extruded length
G1 E19 F200 ; purge nozzle quickly
G1 E30 F60 ; purge nozzle slowly
G92 E0 ; zero the extruded length again
This is what I tried to set it to. Unfortunately, the tag [bed0_temperature] isn't replaced by the actual value, causing the bed not to warm up. So I have to set that to a fixed value at the moment. I only use PLA really so it's not much of a problem for me right now.
Posted: September 22nd, 2016, 8:09 am
You can't use tags for bed hotend there. That weite automatic depending of what you have on the temperatures ara (the tab with the bed/extruder etc)
Posted: September 22nd, 2016, 8:37 am
by MTVDNA
I think you are mistaken. This is from the link I posted from the S3D forums:
Starting G-Code:
This is the G-Code that will be ran after heating up but before your print. Traditionally, this will consist of homing the printer, potentially purging the nozzle, wiping the nozzle and running an auto-leveling function if the printer supports it. In addition, you can add PID values, or set toolhead offsets here if you'd like to.
If you're not a fan of the fact that Simplify3D heats up the bed/extruder, than runs your starting-script, you can customize this, by using the commands below. If you have the commands for [bed#_temperature] or [extruder#_temperature] in your starting G-Code script, the software won't add in heating commands, it will just run off of the commands in your starting script.
[fan_speed_percentage]
[fan_speed_pwm] - for example, M106 S[fan_speed_pwm]
[extruder0_temperature] - for example, M104 S[extruder0_temperature] T0; this will take the layer 1 temperature for extruder 0
[extruder1_temperature]
[bed0_temperature] - for example, M140 S[bed0_temperature] T0; this will take the layer 1 temperature for bed 0
[bed1_temperature]
The hotend temperature is set correctly this way, S3D replaces the tag [extruder0_temperature] with 200 (which is the value I have set in the temperature tab). For the bed this doesn't work, which is a bug I guess.
Edit:
Ah, I found it. On the Temperature tab, under the "Heated Build Platform" settings, the temperature identifier was set to T1. I set it to T0 and now it seems to work.
Posted: September 22nd, 2016, 9:03 am
That yeah.
T0 is bed? No idea I never use that script on the gcode, if you don't add the temp settings on start gcode s3d will add the heating sequence bu itself so dunno. Nice info if someone needs to do it that way.
Posted: September 22nd, 2016, 9:39 am
by MTVDNA
It is a bit confusing. If I understood correctly, here's how it works:
In the overview, there is the Temperature Identifier dropdown menu. You can choose T0, T1, T2, etc.
In the starting script, you can use the settings from this tab, by using the tag [extruder#_temperature] or [bed#_temperature]. The # here corresponds to the temperature identifier you chose in this menu. You can add more extruders, e.g. if you have a dual extrusion print, but then you need to choose a different identifier (T0 for the first, T1 for the second).You can also add another build plate. In practice this might be to set the temperature for a heated chamber or something like that.
So in my case, both the bed and the extruder have identifier 0, so I use those parameters in the starting script as [extruder0_temperature] and [bed0_temperature]. If I were to add another extruder, I would give it identifier T1, and I could access it by using [extruder1_temperature], etc.
Now in my startup script I use
Code: Select all
Note that the T0 here means something different: this tells the printer for which extruder the temperature should be set. As far as I can tell, this value has nothing to do with the T0 from the other tab. (I could be wrong, please correct me if so)
Posted: September 22nd, 2016, 10:32 am
Well I am pleased to see I am not the only one who was confused early on in the configuration of Simplify3D
I've lost more time just configuring it to my printer versus seeing all these amazing things it can do better than Cura!
That said...Neotko made a profile for the UMO Does the default UM2 work well?
Posted: September 22nd, 2016, 11:19 am
by MTVDNA
I don't know, I tossed it out first thing. For some reason the default settings change the motor current of your extruder... Now those are settings I do not want my slicer to change
