PLA sticking TOO much to bed.
Post by Lez0 » July 16th, 2019, 2:40 pm
Hi All
Yes PLA is stick far too much to my vinyl bed. I have to use a knife and a lot of force to get them off.
I have reduce temp from 60 to 50. when levelling the bed I have the paper "feeler" a bit loose. But still it takes a lot to get the print off.
I like all of you have had problems with prints not sticking to the bed so I am hoping I can do a bit of tweaking to reduce the stick.
Thanks all
ps no joke it really is almost impossible to get the prints off-
Re: PLA sticking TOO much to bed.
Post by Roberts_Clif » July 16th, 2019, 7:41 pm
1st of all what bed surface are you using.
I would reduce the temp again to 42C and print with a parts fan on to about half speed.
I might even help to raise the nozzle about 0.05mm using the Z-Offset.
Post by LePaul » July 17th, 2019, 9:23 am
I had LokBuild for a very short time. I even printed with no heat and prints would not come off the thing! I even put bed and all into the freezer overnight, where I finally freed it
Post by Lez0 » July 17th, 2019, 12:33 pm
Thanks for the advice. I'll try lowering the temp and raising the nozzle a bit more.
I'll let you know after the next print.
Post by Lez0 » August 17th, 2019, 3:12 am
I think I may have solved the problem of parts sticking to the bed too much, somehow.
Over 12 hours into this print and the print went for a walk. It must have happened when I left the house..
I think I was pushing it a bit too much.
Post by Roberts_Clif » August 17th, 2019, 6:32 am
I have on many occasions found it sticks so tight that it hard to remove, or it is not quite there and breaks loose.
I have finally purchased a bed surface that will actually hold the print from beginning to end.
Before finding this surface I would print on tape on my First bed surface, as prints would not stick correctly.
The bed surface in the image above would not work for we at all, I finally ripped it from the bed and replaced with a cheap Chinese bed surface. You can find them on E-bay they are sold on lots of 3. Photo was taken in the middle of print, after failing to stick several times to the bed surface..
I have replaced this Chinese surface after 2 years of use, on each of my 3D Printers. An plan to continue using as it works so well.
Just because this particular Bed surface did not work for me does not mean it is a bad Bed surface.
I could not get it to hold the prints. and the tape method did until I again switched to a Chinese bed surface.
