LED lights on the CR10s PRO ?
Posted: July 8th, 2019, 11:09 am
Someone here that knows if any of the UN-used plugs on the plugboard (behind where the ribbon cable is connected to tha gantry) can be used for switching 4 LEDs ON/OFF from a switch I mount beside be screen ?
I assume there is some power to get inside (only <=100 mA) it could be nicer instead of having two extra wires running along the ribbon cable.
