Thank you for all your work!
blc
3D Printer(s): HICTOP 3DP-11
Post by blc »
I'm totally new to the 3D printing world, but I just bought a the HICTOP 3DP-11. Right off the bat I've been extremely impressed with the quality of prints so far, but I can see from the discussions here that there's plenty I can improve on!
Just wanted to say thanks for all the effort that people have put in so far, there's loads of really great information on here!
Re: Thank you for all your work!
Chip has been working hard on that printer!
blc
Post by blc »
No kidding! :)
Chip Luck
Post by Chip Luck »
Awe thanks gang, it's just a printer... right... 8-)
blc
Post by blc »
Chip Luck wrote:Awe thanks gang, it's just a printer... right... 8-)
Yeah, but to a 3D printing noob this place has been invaluable! :)
EdWeb
3D Printer(s): Hictop 3DP-11
Post by EdWeb »
Hi all,
Just built a 3DP-11 as well. I'm being driven to distraction though. I stupidly flashed a different version of Marlin to it because the SD card wasn't working. Now it starts prints a couple of mm above the print bed. I've levelled it correctly etc, but I cannot get it to drop down.
Has anyone got the original firmware that I can reflash?
Chip, you look like you've been doing great work. Are you releasing your version of the firmware?
Chip Luck
Post by Chip Luck »
EdWeb wrote:Hi all,
Ed, look under page 3, dated May 10th for the latest version of firmware I am running on my 3DP-11 HICi3. I had the same problems.
viewtopic.php?f=51&t=189&start=30
You HAVE to *level* and *calibrate* your print bed, firmware does not do that for you. Do not use so called "auto-bed leveling" until you understand all of what is going on. There are how-to's, etc. online for proper bed leveling/setup.
Chip
Return to “General Questions”
