My HICTOP RepRap Prusa Printer - Opinion
Chip Luck
Post by Chip Luck »
Well,
It's been only about a week running this printer and almost have gone through my first spool of PLA filament. After tweaking it, running it (did I mention RUNNING it), and re-tweaking; all I can say is wow. For the money you cannot beat this thing. You have to make sure everything is square, lube those shafts/bearings, LEVEL that bed (and check before each print). Pre-heat, clean nozzle and print. Also, re-check you auto-home function once in a while, and level the Z axis with the motor mounts - then level the bed.
Will be posting my small mod's I have done to make this machine run even better.
But... you HAVE TO RUN IT for a while to break in the bearings, shafts, belts, etc. in. Just like a new car/engine... she don't run smooth until she is used a little! And, re-tighten those belts, and use blue locktite on all those 2mm nuts, or they will fall off.
Have fun, and let's get posting on this thing.
Cheers,
Chip Luck
Return to “General Questions”
