Page 2 of 2
Re: OctoPrint and Cura
Posted: July 10th, 2017, 10:24 am
For S3D if it's an important job I measure the print with this
http://www.gcodeanalyser.com/ is very accurate also
Posted: July 10th, 2017, 10:45 am
Thanks I'll check that out when I get home
Posted: July 13th, 2017, 9:35 am
I'm really enjoying Octoprint and Cura....and uploading for my S3D stuff.
I still need to tweak my timelapse settings on the camera. They run a bit long (which you can easily speed up in a video editor). The camera wanders on it's autofocus. Sometimes locking onto the print head, object printed or beyond. I do like the setup I printed, as having the camera above the printer didn't work well....the rods were always in the way!
Posted: July 14th, 2017, 4:10 pm
by Izzy
I like the way you set it, may have to copy that
Posted: July 14th, 2017, 11:55 pm
Izzy wrote: ↑July 14th, 2017, 4:10 pm
Here it is
https://www.youmagine.com/designs/web-cam-support-bar
Once done, put the bar into each rail, then the printer!
I found using a small clamp works awesome securing the camera (Logitech 615) I can shove the camera forward a bit so you don't see the belts/rod in the picture. Helps with the auto focus
