Anyone knows what causes this?
- 3D Printer(s): Cr10s pro, Prusa mk3s, Dremel 3d45
So my first layer part looked like it went very well. Then the second layer starts doing this. Anyone knows what causes these ripples? Thanks a bunch!
Re: Anyone knows what causes this?
I get that occasionally, depending on the filament and hot-end temperature. I have run temp calibrations before (when I first started), and found that some filaments vary in preferred temperature by as much as 10 degrees. With PLA, I found 190-210 range works best overall. Some filaments require higher temps (210), others preferred 190.
Now just run a lazy medium at 200 since I rarely print anything flat.
I am currently using hatchbox. Any experience using it?
Usually those ripples show you are printing too hot. What are you using for layer 1 and then the rest?
I usually do Hatchbox at 207 then 205 after layer one, 100% fan
I use Hatchbox almost exclusively (better quality for the colors I use). I run at 200 for most everything.
