You might have to scale the outer ring until it is a tight fit though, as I wrote in the PM.Neotko wrote:They printed flawlessly with my perfectrobot settings simulating a 0.28nozzle with my umo+
It is a fine pitch tread, so just slightly too much play and it might collapse under load, it is good if you test this before installing it in the printer.
Here are the files if anyone else is tempted to play with this thing: https://dl.dropboxusercontent.com/u/102 ... cement.zip
The I2K-version is thinner, only use that one if you actually have an I2K-washer installed.
Please note that this is a prototype!
I might spend some more time on this and upload the files somewhere else in the future if I think the designs works good enough.
