UM2 to UM2+ print head upgrade
I know I inquired about this a while back but can't seem to find all the info again.
I'd like to Frankenstein the old UM2 printhead into another machine at some point. But, I would like to upgrade it to UM2+ spec.
Again, nothing to do with the extruder/motor setup. Just printhead
So I know I can find...
1) Olsson Block/35w heater
2) New TFT
3) New fan shroud to fans point down
But I can't figure out what to replace the spring with. I know the UM2+ has a spacer in there, but who sells one?
Re: UM2 to UM2+ print head upgrade
Oh wait....found a post from @Meduza on UM Board
The hotend consists of:
#2283 - Heater Cartridge 35W
#2288 - PT100B sensor
#2278 - TFM Coupler
#2275 - Isolator Spacer
#1310 - Hot end Isolator (the stainless part that sits under the spacer)
#2311 - Olsson Block
@@gr5 to you have the isolator spacer available? I think you have most of these items?
Post by nilrog »
Or you can just print one...fixed or adjustable.
Oh true, I suppose PLA would survive up there?
Post by nilrog »
Maybe, but I would use Greentec just to be on the safe side.
Looking around Youmagine I see @Anders Olsson has a spacer as does @Neotko
LePaul wrote: July 31st, 2017, 9:14 am Looking around Youmagine I see @Anders Olsson has a spacer as does @Neotko
Since you are less a tinkerer and more a print-use-forget. Print a normal spacer or the @gr5 spacer
Anders Olsson spacer allows to adjust the distance. It requieres a fine tuned machine and a good hightemp material for it to work right.
Or better, just order the aluminium spacer to a reseller, it has a specific height and this way you can install it following Ultimaker instructions https://ultimaker.com/en/resources/2218 ... fm-coupler
Any reseller will be able to sell you also the Spacer (printable, search for sandervg on youmagine). This cost 3-4 bucks, and you avoid readjusting stuff and you can just follow UM instructions and avoid tinkering.
No one seems to have that spacer....Fabrc8 doesnt
So weird. Did you mail them?
darkdvd
3D Printer(s): UM2/UM2+
Post by darkdvd »
Neotko wrote: August 1st, 2017, 3:46 am So weird. Did you mail them?
I chat/text with Erin and Simon often
darkdvd wrote: August 1st, 2017, 8:03 am Use this one : https://www.youmagine.com/designs/for-i ... nt-for-um2
Thanks
What's the i2k? Is it needed? Or just the spacer?
darkdvd
Post by darkdvd »
look at this : http://www.ideato3d.be/fr/product-categ ... rs-teflon/
and here : http://3dsolex.com/product-category/ult ... -um-parts/
there is a coupler "TFN" (not TFM...)
and a ring : I2K for high temp (295°C)
