Why is not Slicing?
eltitobarte
3D Printer(s): Creality Ender 3
Why is not Slicing?
Post by eltitobarte »
Hi everyone.
In Cura Software, I'm trying to slice for print a model. My model have an logo in the middle, but when make slice, that logo dissapear, why?
My model:
Sliced Model:
Cura Version: 4.4.1
SETTINGS
Re: Why is not Slicing?
Check the Layer view and go layer by layer...i suspect the brim is hiding it?
Also, if your object is fairly low and flat, don't bother with a brim. Just use a skirt. The brim is used for models with very little first layer surface and decent height. Think of a tube printed on end. The skirt with 3-4 lines will create a steady flow of filament (prime the printhead) for the actual print.
eltitobarte
Well, I tried with skirt Plate Adhesion and still not slicing logo. I tried as well with NONE Plate Adhesion and still not slicing logo.
My model have 9 layers on the bottom, so I think is enougth for show logo. If I rotate 90 degrees the model, the logo is slicing, but it takes 4 hours more for print and it builds supports.
Return to “Cura”
