fail print
gmaldo
3D Printer(s): crealty ld002r
fail print
Post by gmaldo »
Hi
I´m having prints with missing areas, any idea what may be wrong?
Re: fail print
The slicer setting must not be compatible with the wall thickness in areas missing material..
Re: fail print
Hi gmaldo
Could you give us more info.
A screen shot of the part in the slicer software with the missing area shown would be a good start.
gmaldo
Re: fail print
Post by gmaldo »
slicer file seems to be ok, i can see complete part in layer by layer view, the missing area cames in diferent models and diferent zones even with the same model
Re: fail print
I am wandering if the LCD screen is faulty, can you check it.
It could also be a support problem, do you think you have enough.
I've had prints fail even though it printed OK before.
gmaldo
Re: fail print
Post by gmaldo »
well it seems the LCD is the problem, it shows some dark spots . Ill change it and see if that fix the problem, thank you all guys for your help
Re: fail print
Good luck with the LCD.
Please let us know how you get on changing it.
Return to “Resin 3D Printers”
