Hi all,
I am searching for a drag chain that can be opened to put in the cable - similar to IRobertI's design for the UM2 but wider and preferably "buyable" since I need over 1 meter and printing so many parts does not sound too economic
Can you recommend something? I am looking for an outside diameter of approximately 10x30mm.
Best regards,
Reiner
Drag chain recommendations needed!
Re: Drag chain recommendations needed!
Hi reibuehl,
Check out Igus, they have a good range, their part files are also available.
The easy chain from Igus looks very interesting. They have so many options... I need to investigate. I hope they are not too expensive for my budget.
- Meduza
Igus chains are really good and what i would recommend.
Hi !reibuehl wrote:The easy chain from Igus looks very interesting. They have so many options... I need to investigate. I hope they are not too expensive for my budget.
If 10x 20mm would suit, take a look here,
https://www.genapart.com/c%C3%A2blage/
10x20 is what I got with my CNC - that is too tight for USB, controller power and spindle power. I now ordered one from Igus - they are quite affordable, I was surprised how little it costs
