Simplify3d basic guide
Re: Simplify3d basic guide
Well if anything, S3D is providing a lot of changes into the new Cura. I like Cura's interface a lot better.
But I would also like to be one of the gurus, like Neotko and others, than can really take advantage of the software for superb prints.
Well I had to learn S3D because for my stuff it's the best option to make 'out of the box' stuff and also is the best to control big amounts of objects split in many parts that need different settings for each part. To do my keychains with Cura would be just imposible atm.
So is S3D better? I'll just say what I said on one of the first posts, IF you sell stuff and need to go beyond normal prints, yes. If not, just use cura, it works nice to click print. Also new cura has some neat options that close the gab between both programs.
MTVDNA
Post by MTVDNA »
So far my experience with S3D has been very good. Slicing is done much faster than cura, and the print preview is fantastic. I have not played with much settings yet, but I definitely see useful applications for most of them. The idea of processes really appeals to me as well. I've not needed them much yet, but I'm sure I will be using them in the future. They sure allow you to do some interesting stuff rather easily.
antiklesys
Post by antiklesys »
I'm trying to use Neotko's profile and change the filament diameter to 1.75mm
The weird issue is that it seems the machine while using this profile still tries to retract 4.5mm of filament, despite me changing the value to 2.0mm or 1.0mm
For me it's important to use those lower values in order to not jam my E3D v6 head.
Anyone has noticed a similar strange behavior?
That's weird. Can you post your profile to double check?
MTVDNA
Post by MTVDNA »
Are you perhaps using multiple processes? I've had issues before where I thought I changed some setting but midway through a print discovered it wasn't right, only to find out I had changed it only in 1 process in stead of all of them.
antiklesys
Hi Neotko,
Here's my profile, I'm not sure whether it is the nozzle wipe function causing the issue:
Code: Select all
<?xml version="1.0"?>
<profile name="Ultimaker A" version="2017-01-25 22:53:46" app="S3D-Software 3.0.2">
  <baseProfile></baseProfile>
  <printMaterial></printMaterial>
  <printQuality></printQuality>
  <printExtruders></printExtruders>
  <extruder name="Primary Extruder">
    <toolheadNumber>0</toolheadNumber>
    <diameter>0.4</diameter>
    <autoWidth>0</autoWidth>
    <width>0.4</width>
    <extrusionMultiplier>1</extrusionMultiplier>
    <useRetract>1</useRetract>
    <retractionDistance>1</retractionDistance>
    <extraRestartDistance>0</extraRestartDistance>
    <retractionZLift>0</retractionZLift>
    <retractionSpeed>2100</retractionSpeed>
    <useCoasting>1</useCoasting>
    <coastingDistance>0.5</coastingDistance>
    <useWipe>1</useWipe>
    <wipeDistance>1</wipeDistance>
  </extruder>
  <primaryExtruder>0</primaryExtruder>
  <layerHeight>0.2</layerHeight>
  <topSolidLayers>3</topSolidLayers>
  <bottomSolidLayers>3</bottomSolidLayers>
  <perimeterOutlines>2</perimeterOutlines>
  <printPerimetersInsideOut>1</printPerimetersInsideOut>
  <startPointOption>2</startPointOption>
  <startPointOriginX>0</startPointOriginX>
  <startPointOriginY>0</startPointOriginY>
  <startPointOriginZ>300</startPointOriginZ>
  <sequentialIslands>1</sequentialIslands>
  <spiralVaseMode>0</spiralVaseMode>
  <firstLayerHeightPercentage>140</firstLayerHeightPercentage>
  <firstLayerWidthPercentage>140</firstLayerWidthPercentage>
  <firstLayerUnderspeed>0.35</firstLayerUnderspeed>
  <useRaft>0</useRaft>
  <raftExtruder>0</raftExtruder>
  <raftLayers>3</raftLayers>
  <raftOffset>3</raftOffset>
  <raftSeparationDistance>0.14</raftSeparationDistance>
  <raftInfill>85</raftInfill>
  <disableRaftBaseLayers>0</disableRaftBaseLayers>
  <useSkirt>1</useSkirt>
  <skirtExtruder>0</skirtExtruder>
  <skirtLayers>1</skirtLayers>
  <skirtOutlines>2</skirtOutlines>
  <skirtOffset>4</skirtOffset>
  <usePrimePillar>0</usePrimePillar>
  <primePillarExtruder>999</primePillarExtruder>
  <primePillarWidth>12</primePillarWidth>
  <primePillarLocation>7</primePillarLocation>
  <primePillarSpeedMultiplier>1</primePillarSpeedMultiplier>
  <useOozeShield>0</useOozeShield>
  <oozeShieldExtruder>999</oozeShieldExtruder>
  <oozeShieldOffset>2</oozeShieldOffset>
  <oozeShieldOutlines>1</oozeShieldOutlines>
  <oozeShieldSidewallShape>1</oozeShieldSidewallShape>
  <oozeShieldSidewallAngle>30</oozeShieldSidewallAngle>
  <oozeShieldSpeedMultiplier>1</oozeShieldSpeedMultiplier>
  <infillExtruder>0</infillExtruder>
  <internalInfillPattern>Fast Honeycomb</internalInfillPattern>
  <externalInfillPattern>Rectilinear</externalInfillPattern>
  <infillPercentage>25</infillPercentage>
  <outlineOverlapPercentage>25</outlineOverlapPercentage>
  <infillExtrusionWidthPercentage>100</infillExtrusionWidthPercentage>
  <minInfillLength>1</minInfillLength>
  <infillLayerInterval>1</infillLayerInterval>
  <infillAngles>0</infillAngles>
  <overlapInfillAngles>0</overlapInfillAngles>
  <generateSupport>0</generateSupport>
  <supportExtruder>0</supportExtruder>
  <supportInfillPercentage>25</supportInfillPercentage>
  <supportExtraInflation>0</supportExtraInflation>
  <denseSupportLayers>0</denseSupportLayers>
  <denseSupportInfillPercentage>70</denseSupportInfillPercentage>
  <supportLayerInterval>1</supportLayerInterval>
  <supportHorizontalPartOffset>0.3</supportHorizontalPartOffset>
  <supportUpperSeparationLayers>1</supportUpperSeparationLayers>
  <supportLowerSeparationLayers>1</supportLowerSeparationLayers>
  <supportType>0</supportType>
  <supportGridSpacing>4</supportGridSpacing>
  <maxOverhangAngle>45</maxOverhangAngle>
  <supportAngles>45,-45</supportAngles>
  <temperatureController name="Primary Extruder">
    <temperatureNumber>0</temperatureNumber>
    <isHeatedBed>0</isHeatedBed>
    <relayBetweenLayers>0</relayBetweenLayers>
    <relayBetweenLoops>0</relayBetweenLoops>
    <stabilizeAtStartup>1</stabilizeAtStartup>
    <setpoint layer="1" temperature="200"/>
  </temperatureController>
  <temperatureController name="Bed">
    <temperatureNumber>2</temperatureNumber>
    <isHeatedBed>1</isHeatedBed>
    <setpoint layer="1" temperature="60"/>
  <fanSpeed>
    <setpoint layer="1" speed="0"/>
    <setpoint layer="6" speed="50"/>
    <setpoint layer="16" speed="80"/>
  </fanSpeed>
  <blipFanToFullPower>0</blipFanToFullPower>
  <adjustSpeedForCooling>1</adjustSpeedForCooling>
  <minSpeedLayerTime>5</minSpeedLayerTime>
  <minCoolingSpeedSlowdown>40</minCoolingSpeedSlowdown>
  <increaseFanForCooling>1</increaseFanForCooling>
  <minFanLayerTime>7</minFanLayerTime>
  <maxCoolingFanSpeed>100</maxCoolingFanSpeed>
  <increaseFanForBridging>1</increaseFanForBridging>
  <bridgingFanSpeed>100</bridgingFanSpeed>
  <use5D>1</use5D>
  <relativeEdistances>0</relativeEdistances>
  <allowEaxisZeroing>1</allowEaxisZeroing>
  <independentExtruderAxes>0</independentExtruderAxes>
  <includeM10123>0</includeM10123>
  <stickySupport>1</stickySupport>
  <applyToolheadOffsets>0</applyToolheadOffsets>
  <gcodeXoffset>0</gcodeXoffset>
  <gcodeYoffset>0</gcodeYoffset>
  <gcodeZoffset>0</gcodeZoffset>
  <overrideMachineDefinition>1</overrideMachineDefinition>
  <machineTypeOverride>0</machineTypeOverride>
  <strokeXoverride>210</strokeXoverride>
  <strokeYoverride>210</strokeYoverride>
  <strokeZoverride>205</strokeZoverride>
  <originOffsetXoverride>0</originOffsetXoverride>
  <originOffsetYoverride>0</originOffsetYoverride>
  <originOffsetZoverride>0</originOffsetZoverride>
  <homeXdirOverride>-1</homeXdirOverride>
  <homeYdirOverride>-1</homeYdirOverride>
  <homeZdirOverride>-1</homeZdirOverride>
  <flipXoverride>1</flipXoverride>
  <flipYoverride>-1</flipYoverride>
  <flipZoverride>1</flipZoverride>
  <toolheadOffsets>0,0|0,0|0,0|0,0|0,0|0,0</toolheadOffsets>
  <overrideFirmwareConfiguration>1</overrideFirmwareConfiguration>
  <firmwareTypeOverride>RepRap (Marlin/Repetier/Sprinter)</firmwareTypeOverride>
  <GPXconfigOverride>r2</GPXconfigOverride>
  <baudRateOverride>250000</baudRateOverride>
  <overridePrinterModels>1</overridePrinterModels>
  <printerModelsOverride></printerModelsOverride>
  <startingGcode>G28 X0 Y0 ;move XY to min endstop,G28 Z0 ;move Z to min endstops,G1 Z15.0 F500 ;move the platform down 15mm,G92 E0                  ;zero the extruded length,G1 F200 E9              ;extrude 9mm of feed stock,G92 E0                  ;zero the extruded length again</startingGcode>
  <layerChangeGcode></layerChangeGcode>
  <retractionGcode></retractionGcode>
  <toolChangeGcode></toolChangeGcode>
  <endingGcode>;End GCode,G91                                    ;relative positioning,G1 E-1 F300                            ;retract the filament a bit before lifting the nozzle to release some of the pressure,G1 Z+15 E-2 X-20 Y-20 F3000 ;move Z up a bit and retract filament even more,G28 X0                              ;move X to min endstops so the head is out of the way,M140 S0                     ;heated bed heater off (if you have it),M104 S0		;extruder heater off,M107		; fans off,M84                         ;steppers off,</endingGcode>
  <createX3G>0</createX3G>
  <celebration>0</celebration>
  <celebrationSong>Random Song</celebrationSong>
  <createMB5G>0</createMB5G>
  <postProcessing></postProcessing>
  <defaultSpeed>4200</defaultSpeed>
  <outlineUnderspeed>0.9</outlineUnderspeed>
  <solidInfillUnderspeed>0.9</solidInfillUnderspeed>
  <supportUnderspeed>0.8</supportUnderspeed>
  <rapidXYspeed>10800</rapidXYspeed>
  <rapidZspeed>1500</rapidZspeed>
  <minBridgingArea>1</minBridgingArea>
  <bridgingExtraInflation>0.2</bridgingExtraInflation>
  <bridgingExtrusionMultiplier>1.1</bridgingExtrusionMultiplier>
  <bridgingSpeedMultiplier>0.5</bridgingSpeedMultiplier>
  <filamentDiameter>1.75</filamentDiameter>
  <filamentPricePerKg>25</filamentPricePerKg>
  <filamentDensity>1.25</filamentDensity>
  <useMinPrintHeight>0</useMinPrintHeight>
  <minPrintHeight>0</minPrintHeight>
  <useMaxPrintHeight>0</useMaxPrintHeight>
  <maxPrintHeight>0</maxPrintHeight>
  <useDiaphragm>0</useDiaphragm>
  <diaphragmLayerInterval>20</diaphragmLayerInterval>
  <robustSlicing>1</robustSlicing>
  <mergeAllIntoSolid>0</mergeAllIntoSolid>
  <onlyRetractWhenCrossingOutline>0</onlyRetractWhenCrossingOutline>
  <retractBetweenLayers>1</retractBetweenLayers>
  <useRetractionMinTravel>1</useRetractionMinTravel>
  <retractionMinTravel>0.5</retractionMinTravel>
  <retractWhileWiping>1</retractWhileWiping>
  <onlyWipeOutlines>0</onlyWipeOutlines>
  <avoidCrossingOutline>0</avoidCrossingOutline>
  <maxMovementDetourFactor>1</maxMovementDetourFactor>
  <toolChangeRetractionDistance>12</toolChangeRetractionDistance>
  <toolChangeExtraRestartDistance>-0.5</toolChangeExtraRestartDistance>
  <toolChangeRetractionSpeed>600</toolChangeRetractionSpeed>
  <allowThinWallGapFill>1</allowThinWallGapFill>
  <thinWallAllowedOverlapPercentage>25</thinWallAllowedOverlapPercentage>
  <horizontalSizeCompensation>0</horizontalSizeCompensation>
</profile>
antiklesys wrote:Hi Neotko,
I don't see anything weird on the profile. Maybe I would remove the coasting and cut wipe distance.
Oh also an important thing. If you use wipe distance and activate Retract while whipping, the amount of wipe only depends on the speed and amount of retractions.
Anyhow... Umm make a gcode, a simple cube and check the gcode generated.
The only bug I had with s3d retraction is when one uses two processes and two different extruders, then S3D goes crazy and if you use retract while wipping, it gets the value of toolchange retract and makes all the wipes of the retraction distance + toolchange distance. Making quite a lot of stress on the feeder (and lots of weird noises).
Edit. the option is called 'Perform retraction during wipe movement'. Also I recommend you use the option 'Only wipe extruder for outer-most perimeters'. All in Advanced tab. Also remember that I do minimum 0.50mm retraction distance because I use bondtech. With the mk7 I was using 1.00mm and 0.50 only for the text parts, but now with the bondtech I use 0.50 and 0.25 sometimes.
Also, change the retraction speed to the extruder speed. I think umo+ has 25mm/s limit by default. I changed this on mine, but in the end I work with 25mm/s to avoid the pitch of the noise XD or 100mm/s for flexibles ofc.
antiklesys
Hi Neotko,
I'll have a look at this. Right now I'll continue experimenting and may need to change drastically those values in the future as I'm planning to switch to a direct extruder.
As I run on 1.75 mm filament that will also the best way for me to start playing around with flexible filaments :)
Hopefully, if all goes well: bowden long be gone! :D
I just got @Gudo packet with his ZGE. Planning to install it tomorrow morning. So yeah, flexibles here too :D
antiklesys
Neotko wrote:I just got @Gudo packet with his ZGE. Planning to install it tomorrow morning. So yeah, flexibles here too :D
Link please :)
Gudo ZGE extruder?
viewtopic.php?t=510
antiklesys
Yes, I know that. I was hoping for a link to the stl files :)
Patience is key :P
I had to leave home but left a first test print with it
Return to “Simplify 3D”
