Layer splitting with ABS
Your ABS brand not mentioned in the categories? Chat about it here
Re: Layer splitting with ABS
Found out why part of the print was not very good.
I used Cura with "Use adaptive layers" set with the default settings.
This was used to cut the print time down, but resulted in crappy walls.
I wouldn't be using this setting again.....
Return to “ABS Filament General Discussion”
