Page 12 of 23
Re: Fan shroud upgrade
Posted: May 13th, 2016, 2:31 pm
Neotko wrote:Well the 50x50 bottom_left & right and the fancap it's updated. I shouldn't hit the frame anymore. Anyway someday I'll try to rebuild the full rhino file of this size to properly redo it. Anyhow seems it's ok.
Okay well since I have CF loaded in the machine, maybe I'll try this tonight!
(And buy beer on the way home, you know, just in case
Posted: May 13th, 2016, 2:47 pm
I would like to pla test it but I want to focus on my beyond slideblocks. So far they are working nice but I need to run tests with the real um2 shafts. I want the full print bed available
Btw if the fancap bends by fan weigh I just know the sollution will be very easy by making the bottom-left/right just 0.6-0.8 taller to gain enough hardness.
Ummm. I'm gonna go and upload that change. That should fix any future problem.
Posted: May 13th, 2016, 2:49 pm
To the 50x50 one?
I was looking at the file in Cura. Up on its side (like the tutorial pic!) with 'Support Type: Everywhere'
I'm really really curious how the CF will do with this...the support material will be inside the model so I hope it comes out really well. (Like you said, forget bridging!)
Posted: May 13th, 2016, 2:56 pm
by Amedee
Neotko wrote:Oh also Amedee. I made all the Rhino/Step files available for 30-40 size fans.
Yes, thank you for that!
I don't have Rhino (I should ask my daugther...) but I already have loaded the steps in F360
Not that I wanted to change something at this point in time, but it is easier to visualize.
Posted: May 13th, 2016, 2:59 pm
Ok 50x50 version botom-left/right and fancap updated. Titus, if you print bottomleft/right they should work on pla and fix that curve for good. But probably since the Bottom-right it's near the peek it might need carbon/abs/ngen to last longer.
Posted: May 13th, 2016, 3:07 pm
The fancap, to print it, you need to print it like on the image sandervg uploaded from his cura.
Also change the angle of supports to 70 degrees so you don't generate more supports than needed. Basically the idea it's to use support only on the areas that would bridge on pla. I suppose with ngen or pla-tec it would bridge perfectly like it does on pla.
Posted: May 13th, 2016, 3:12 pm
Amedee wrote:Neotko wrote:Oh also Amedee. I made all the Rhino/Step files available for 30-40 size fans.
If you open the rhino it has everything on two sides 'hideswap' command changes that. One side has the fancap assembled parts and the other all the splines that generate all the structure. The inner lines are on 'history' mirroed so when you change one the other adjust, this way when you make the 'loft' command you can readjust the airexit quite fast in realtime.
Posted: May 13th, 2016, 3:15 pm
I have my Fill , Bottom/Top thickness set to 1.2 Asides that, everything matches. Plus the combing off and retraction 15mm/sec and 4mm
Posted: May 13th, 2016, 9:06 pm
Off we go. 5.7 hours to go since I opted to print slower (40 mm/sec)
Posted: May 13th, 2016, 9:37 pm
Is the Top Left and Top Right pieces needed in the 50mm?
Just looking at what I print next!
Posted: May 13th, 2016, 9:53 pm
I'm at a loss why the supports look so bad on one side
Posted: May 14th, 2016, 3:14 am
It's me or your walls don't touch? Maybe it's the photo but seems they have gaps.
Posted: May 14th, 2016, 10:32 am
Somehow, by the grace of God, I have a usable part
But now I am wondering if I should consider replacing the pieces above the heater block (I have spare parts from the dual extruder Kit I never used)
Posted: May 14th, 2016, 10:37 am
After removing some support material.
Boy this stuff (CF20) can't bridge at all even with support.
Posted: May 14th, 2016, 12:14 pm
Carefull cleaning it. It stings like a b..
