Cura wish list
nallath
3D Printer(s): Ultimaker
Re: Cura wish list
Post by nallath »
PeggyB wrote:
nallath wrote: Yep :) (ctrl + up / down) to be precise
This doesn't work on MacOS (10.10.5) this combination shows all my open windows next to each other.
Whoops. Added it to the list. Ctrl + up / down is the only way to step through them at the moment.
PeggyB wrote: In legacy Cura, if you choose 'none' you actually got something .... a skirt... ;-)
Well, that's bad and we should feel bad ;)
nallath
Re: Cura wish list
Post by nallath »
Soo, any more issues? I'm pretty sure there are ;)
martin-bienz
Re: Cura wish list
Post by martin-bienz »
nallath, so it's better to reply here :)
I have some issues with the settings. When I selected UMO for a new machine and then finished the wizard (I select either HBK or HB self supplied) I don't see the HB Temperature in the settings. I tried to enable / disable / restart and so on... did not work, I never see the Heated Bed temperature in the material settings. Bug?
It works if I create a new UMO+.
btw: I deleted the cura settings completly in appdata so cura could restart from scratch. tried again, same behaviour. In the exported gcode, the bed will be set to target temperature, so it is "gui" only, that is not working.
Another issue, when I load an stl, rotate it twice, first y 90 then x -90, and switch to layer view (without changing anything else), the roatation is not reflected, only AFTER I change something (for instance temp) it does slice it again and the transformation is applied. This only happens if I load an object after a fesh cura start. Not if I reset the transformation, position. Nor re-loading the object while cura is running.
Re: Cura wish list
Post by ivan.akapulko »
nallath wrote:Soo, any more issues? I'm pretty sure there are ;)
When switching between multiple printers hangs slicing, and you have to restart Cura. Also on my computer Сura did not close completely: window close, but program hung in memory, and had to kill manually.
nallath
Re: Cura wish list
Post by nallath »
Could you send me the log files?
martin-bienz
Re: Cura wish list
nallath, I guess you are reffering to ivan.akapulko's post, not to mine?
Re: Cura wish list
Where do I find the logs? They are not in the program folder.
Titus
Re: Cura wish list
Post by Titus »
@Nallath, I'm not a power user, but always interested in trying out new things to provide testing/feedback :) If you need more people, hook me up ;)
nallath
Re: Cura wish list
Post by nallath »
Titus wrote:@Nallath, I'm not a power user, but always interested in trying out new things to provide testing/feedback :) If you need more people, hook me up ;)
You've got mail :)
@martin-bienz; Yeah
@ivan.akapulko: https://github.com/Ultimaker/cura#logging-issues (It tells you where the log files are)
martin-bienz
Re: Cura wish list
nallath wrote: @martin-bienz; Yeah
okay :) tell me when I can do something for you re my post.
nallath
Re: Cura wish list
Post by nallath »
There should be at least 10 bug fixes in the next build :D
PeggyB
Re: Cura wish list
Post by PeggyB »
I found a way to scroll through the layer view!
(Mac) click in the layer number slider box and use the up or down arrow...
nallath
Re: Cura wish list
Post by nallath »
Oh, yeah, forgot about that one :$
PeggyB
Re: Cura wish list
Post by PeggyB »
it is quit messy, not following the universal rules of key behavior.......
using 'tab' switches between
rotating: just left/right or up/down, no other key necessary.
scrolling layer height: only up/down, no other key necessary.
confusing....
nallath
Re: Cura wish list
Post by nallath »
New build is up. Ton of fixes including;
* Cura launch failure on WIN32 systems
* Slicing should stop when there are no printable objects.
* UM 2 Go & UMO now have brim enabled by default
* Switching machines no longer causes OpenGL to crash
* Changing infill thickness no longer causes crash
* Empty print name in lower right corner is now always adjustable (even when name is empty)
* Grey out settings that are not machine related.
* Improved Readability 'print time' & 'dimensions'
* Moved objects can no longer overlap
* Eject SD card should work correctly now(fixed for Mac. Windows still gives an error, but is correctly unmounted)
* Typing a 'dot' in an input field should no longer remove the dot
