Page 5 of 6
Re: Cura wish list
Posted: March 11th, 2016, 10:43 am
You guys should get into the Closed Beta group
Re: Cura wish list
Posted: March 11th, 2016, 10:59 am
by nallath
Pretty much everyone here got an invite. Sending the issues to me has almost the same impact compared to the other options out there (eg; Asana)
Re: Cura wish list
Posted: March 11th, 2016, 11:02 am
I just replied to Marrit, I've been down with this flu/bronchitis thing all week Finally starting to feel better so I will download it tonight and try it out
Asana is a bit of a pain (I'm used to JIRA at work), so glad to share feedback here too
Re: Cura wish list
Posted: March 11th, 2016, 11:14 am
by martin-bienz
I am really not sure if I am actually the only one with this, installed the new version (on Win7, 64 Bit also Cura64Bit). I also uninstalled the "old" Cura first.
I get the following when creating a new UMO (with either HB or HB self supplied & feeder upgrade). I do not see the Heated bed temperature in the settings:
If I take an UM+ as the machine, it works no problem:
Is it me? :geek:
Re: Cura wish list
Posted: March 11th, 2016, 11:53 am
by PeggyB
yep, same here...
Re: Cura wish list
Posted: March 11th, 2016, 12:12 pm
Downloading the Win 64-bit version now to try
Re: Cura wish list
Posted: March 11th, 2016, 12:18 pm
He's correct
It IS showing in the Settings so it should be displaying on the main screen?
It appears to me that area you have allocated for items listed under Material may be out of room to display bed temperature?
Re: Cura wish list
Posted: March 14th, 2016, 4:23 am
by nallath
UMO with heated bed upgrade kit seems to have some problems. It has to do with the order in which we create items.
Re: Cura wish list
Posted: March 14th, 2016, 8:45 am
Okay, that's good to know. I think one of the previous Betas you had to check it off in Settings to appear
Re: Cura wish list
Posted: March 15th, 2016, 12:06 pm
by nallath
Allrighty! Fixed that sucker for the next release. Having an UMO with HBK should now correctly enable bed temperature setting.
Re: Cura wish list
Posted: March 15th, 2016, 1:39 pm
When's the next release?
Re: Cura wish list
Posted: March 16th, 2016, 9:19 am
by nallath
18th of march. Will upload it to the 'default' closed beta spot.
Re: Cura wish list
Posted: March 17th, 2016, 5:21 pm
by nilrog
I just filed a new issue at GitHub regarding the use of a "weird" location for saving user settings on disk in OS X. And the fact that there is no (empty) "plugins" folder in the current folder that indicates where you can put plugins for Cura.
Re: Cura wish list
Posted: March 18th, 2016, 4:51 am
by nallath
Not sure if we are going to have that fixed for 2.1 though.
Re: Cura wish list
Posted: March 18th, 2016, 11:51 am
by nallath
The release of today is pushed back a bit. We've found some regressions, so it won't be released today.
**Edit**
Nevermind guys; It is online. The issue we had is only triggered when slicing very big (volume wise) objects with ultra high setting with high infills. So if the slicing freezes, just nudge the object and let the reslice do it's work (or restart if it reaaaly refuses to restart)
