New large print with CR-10 S5
Creality brand 3D Printers!
Mbur1
3D Printer(s): Creality CR-10 S5
Post by Mbur1 »
Hello,
I am going to try a large print on a CR-10 S5. Basically the model is a shoe box 8” tall with some ribs and towers in the middle. I am using Cura to slice the file but have a few questions about infil and Z pick ups. Is it better to use Z hops or not? What is a sand infil amount? Also any other advice or tips would be appreciated this will be a long print and want to try to get it right.
Thank you.
Re: New large print with CR-10 S5
Have a look at this video, it will give you some ideas.
Seen it!
And was intrigued.
Thanks for the reminder...
I'll have to check this out
Generally, I use zhop of 1mm
For whatever reason, the Ultimaker has always liked to rub the previously layer....not sure why!
Mbur1 wrote: February 28th, 2019, 9:35 am Hello,
Thank you.
There are so many things to printing a good model it is hard to list them.
I use the internet and search for certain ways to improve the models, though this is a good time to post this help tutorial.
https://all3dp.com/1/cura-tutorial-soft ... r-cura-3d/
