Change Filament Option
Posted: March 6th, 2019, 7:13 am
Hello,
Is there a firmware update for the CR-10 S5 controller. I needed to change my filament during a print and when I followed the steps to go to Tune then to change filament the option was not in the list? I finally cut the line to let it run out of the filament sensor. This did work and I was able to change the spool. Also has anyone recovered from a power loss?
Thank you.
Thank you.
