LEDs to light up the nozzle on a CR10s PRO ??
ksor
3D Printer(s): CR10s PRO
Post by ksor » July 8th, 2019, 4:03 am
I have a CR10s PRO and I thought I had fastened ALL screws but ... oh, I missed the one holding the spring loaded lever for the filament feeder and it got loose and nearly fell off !
Now that I have a breakdown and the X-grantry apart because of loose screws all over I want to design a frame/brachet to hold 4 LEDs nearby the nozzle so I can see what's going on there especially at the first layer.
I can see there is some un-used sockets at the plug board behind where the ribbon cable is pligged in.
I plan to use 4 LEDs with a current use of less than 100mA placed near/around the nozzle.
Could I just switch them into the circuit with the constant running blower or should I make a separate cable (and then maybe even a ON/OFF switch) ?
Any of you have experience, maybe even made light down there ?
Re: LEDs to light up the nozzle on a CR10s PRO ??
Post by LePaul » July 10th, 2019, 7:00 pm
That's interesting... I don't have a Pro so asides the Creality FB group, I don't have much to offer on this one
