Just wanted to ask if anyone can explain what is the last two files for the 3DP-12 here ?
The files in question are:
Use E1 instead of E0 port
Source Code
Hictop Factory Firmware
Re: Hictop Factory Firmware
Yes the Use E1 instead of E0 port Allows you to use the 2nd extruder in lieu of the first extruder.
The Source Code file gives you a un-compiled version of the firmware that you can be modified to your own designs.
- OR -
You can Change the Hardware and Compile it for your New Hardware selected.
- OR -
