Hi,
Lately my Creality Ender 3 does not seem to get the information about the nozzle temperature when I started printing. Its always 0.
The bed temperature is correctly set.
I can still print but every print I need to set the nozzle temperature manually.
It is set correctly to 260 in Materials and I can see it on the screen in Cura before printing.
Used to work without problems in the past. I even tried some of the default materials and i's the same issue.
Any help is appreciated.
Thank you
Adrian
Creality Ender 3 Cura miscommunication
- 3D Printer(s): ender 3
Re: Creality Ender 3 Cura miscommunication
Sounds like the thermal sensor is broken. You should be able to replace it. I've had to replace several on my printers in the past. They are very delicate glass beads.
Sorry, I think I was not clear enough.
I can manually set the temperature and the display show it and it works perfectly.
The problem is that when I load any new files the nozzle set temperature shows zero.
It's like the file does not transfer the temperature setting to the machine for the nozzle. It does it fine for the bed.
Thank you
Adrian
Thank you
Adrian
Oh, that may be a different issue. Check that you are setting up the correct extruder in Cura (or whatever you are using). Also check that the temperature setting is correct for your print. You can check the gcode file that is sent to the printer, just look for 'M109 S###' (where ### is the temperature setting for your print). The gcode file is plain text, so even Windows Notepad can look at it (just don't save from Notepad).
I checked and my file looks like I have that temperature (26) in 2 places : 104 and 109 as below.
;FLAVOR:Marlin
;TIME:268
;Filament used: 0.133363m
;Layer height: 0.2
;MINX:89.748
;MINY:33.265
;MINZ:0.2
;MAXX:130.252
;MAXY:76.735
;MAXZ:2
;Generated with Cura_SteamEngine 4.3.0
M140 S100
M105
M190 S100
M104 S260
M105
M109 S260
M82 ;absolute extrusion mode
M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration
M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate
M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration
M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
M220 S100 ;Reset Feedrate
M221 S100 ;Reset Flowrate
Thank you,
Adrian
;FLAVOR:Marlin
;TIME:268
;Layer height: 0.2
;MINX:89.748
;MINY:33.265
;MINZ:0.2
;MAXX:130.252
;MAXY:76.735
;MAXZ:2
M140 S100
M105
M190 S100
M104 S260
M105
M109 S260
Thank you,
Adrian
