DLP dimensional issues on larger areas
Posted: August 3rd, 2020, 9:25 am
Hi everyone. I'm wondering if anyone can help me determine what might be going on here. It's oddly much more difficult to see in photos, but nonetheless: I seem to be having an issue where there are dimensional inaccuracies in certain areas of prints when the exposed surface area increases. Hopefully you can see that the edge of this drawer pull isn't straight.
Details:
Duplicator 7
NanoDLP
Esun Hard-Tough Resin
Printed twice. Once with moderate settings, again with extremely conservative/slow settings.
Theories tested and not at fault due to test #2:
- not enough reflow time (wait after lift). Thought this was it given the viscosity of the Resin.
- not enough wait before exposure (not drastically changed though)
- lift too fast causing supports to move.
Theories:
- not enough supports for the uppers section. Though there seems to be a lot already!
- resin has a Young's modulus or 1350MPa, so is a little flexible (particularly during print). Perhaps they move during lift and don't return? Though I've slowed this down so much that it doesn't seem to be the case.
- overcure? I do have pixel dimming enable to hopefully help with this.
- as mentioned, there is some correlation between area and this phenomenon. In this print, it happens in the area where the surface area increases as it goes from Just not sure what exactly causes it in combination with that.
- trying a different resin as a test
Any ideas or tests would be extremely helpful. Thanks everyone.
Details:
Duplicator 7
NanoDLP
Theories:
