Cura 15.04.6
Posted: October 24th, 2020, 8:19 am
Is there a reason why Cura 15.04.6 will not generate a Support for the attached link model mask_middle_v1.stl
https://www.thingiverse.com/thing:4242337
I would appreciate any help in setting Up Cura 15.04.6 supports for the above model.
Thank You
Re: Cura 15.04.6
Posted: October 24th, 2020, 8:36 am
by Country_Bubba
Hi,
I believe 15.04.6 is a very old version of Cura and is no longer supported. The current version is I think 4.7.1. The version numbering changed about the time I started 3D printing so do not know the reason for the new vs old numbering scheme.
Re: Cura 15.04.6
Posted: October 24th, 2020, 9:04 am
by reibuehl
Hi @Roberts_Clif,
I just had alook at the link you posted and couldn't find a mask_middle_v1.stl there. I found a "Scorpion_-_corona_respirator_-_filter_middle.stl" which seems to have a flat bottom and no supports needed and a "Scorpion_-_corona_respirator_-_mask.stl" which I tested - I also still have a version of 15.04.6 installed, just in case
- and for me it generated supports for that file. Attached a screenshot of the layer view that shows the supports and a second screenshot that shows the settings used. Machine is a UM2 with Olsson Block.
Best regards,
Reiner
Re: Cura 15.04.6
Posted: October 24th, 2020, 9:53 am
After downloading the mask I could not find the exact mask so left a link to a similar one.
Above is the mask I Have. model can not get support on in upper right.
Thank you for your assistance.
Re: Cura 15.04.6
Posted: October 24th, 2020, 7:00 pm
To all who helped Thank You.
What I found was on " Ultimaker Community of 3D Printing Experts " posted by Labern " you can change the x-y distance "
Started to Play with the Distance X/Y (mm) found that a change from 0.7 to 0.8 was all it took now I have supports in Cura 15.04.6.
Re: Cura 15.04.6
Posted: November 2nd, 2020, 4:30 pm
Well glad you found the answer....but also curious why you'd opt to run the 2017(?) version of Cura?
Re: Cura 15.04.6
Posted: November 2nd, 2020, 7:28 pm
Cura 15.04.6 is a tried and true Slicer, it works every time for me.
Sometimes I have problems with newer Version of Cura above Version 3.6.
Working with Slic3r a lot more now that I have found the secret settings for the slicer.
