Nozzle Hitting Problem
Posted: November 11th, 2020, 7:36 am
by Vampire
I use Cura.
I built my printer myself. DIY printer.
I did a table calibration. Dimensions are fine.
You can watch the video. Especially the second 48.
I couldn't solve this problem. The nozzle hits the output.
https://drive.google.com/file/d/1CZFyr5 ... jYPrx/view
Re: Nozzle Hitting Problem
Posted: November 11th, 2020, 3:27 pm
With Cura and Simplify3D, I also set Z hop /vertical lift to 1.0mm
Posted: November 12th, 2020, 9:51 am
Hello Vampire
Would you be so kind as to post your Cura version, Cura Profile, filament specs, style of 3D Printer.
Like to go through your settings to see if there could be some configuration changes that could help improve your current dilemma.
Some of the changes could include Z-Hop when retracting, Retraction speed and distance, Print Speed, Print temperature, ect. ect.
Posted: November 13th, 2020, 6:27 am
by Vampire
@Roberts_Clif
@LePaul
Thanks. I will upgrade the Y-axis of my printer and try again. I'll test it again with a 0.4mm nozzle in a few days.
Posted: December 11th, 2020, 4:55 pm
by Vampire
I bought BLTouch and my problem was solved.
