I found this great little bag clip and have been printing several for every member of the family.
Re: What are you printing lately?
Posted: March 23rd, 2021, 12:33 pm
by Lez0
I've been printing various things for work.
I have a very interesting project that I 3D printed as a sort of prototype to see how it all fitted together.
When I get permission I'll post some photos of it.
Posted: March 24th, 2021, 11:49 pm
Did this
Posted: April 1st, 2021, 10:13 am
by Lez0
The other end of the scale, size wise.
These small gears are for a project I am working on.
Posted: May 9th, 2024, 4:10 pm
by dbhosttexas
Raspberry Pi 5 / Pimoroni base cases.
Ryobi BT3x00 sliding miter fence ends
Ethernet cable organizers
Eero pro 6 wall mounts.
Tie Fighter Echo Dot V3 desktop stands
In design phase of camper van wall mount electrical control panel. I.E. wall mounted box that will house 12V power sockets, USB charging ports, water pump control switch, gray and fresh water level sensors / switch, Thermostat and controls for AC and heat. Control / data panel for inverter.
In design phase of... Updated bottom half of Raspberry Pi 5 / Pimoroni base cases, Simply adding mounting tabs to permit me to wall mount the Pi in the camper van. Simply taking the STL file and adding an ear with a hole through it for the screws on each corner, Probably bevel the hole for flat screws.
Because of the high UV exposure / automotive nature of the 2 in progress designs, I am trying to learn to print with PETG, and that stuff is a bit, fussier than PLA... I'll get there, I hope.
