STL 300x300 auf Druckbrett 300x300 Platzieren?!?
Posted: August 3rd, 2021, 3:06 pm
by andzbro
Ich habe eine STL Datei in 300x300mm erstellt für meinen Sidewinder x1 der genau 300x300x400mm drucken kan aber bekomme diese nicht "ordnungsgemäß" auf der druckfläche platziert. irgendwer eine ahnung wie man das "platziert"?
Re: STL 300x300 auf Druckbrett 300x300 Platzieren?!?
Posted: August 4th, 2021, 6:56 pm
Translated
I have created an STL file in 300x300mm for my Sidewinder x1 which can print exactly 300x300x400mm but do not get it "properly" placed on the printing surface. anyone has any idea how to "place" this?
Posted: August 4th, 2021, 7:06 pm
Are you using Cura or Simplify3d? You should be able to center/place a model with ease
Can you attach the STL?
Posted: August 5th, 2021, 3:45 am
by andzbro
LePaul wrote: ↑August 4th, 2021, 7:06 pm
Ich nutze Cura.
Ich habe mal die Fehlermeldung im Anhang gepostet.
Posted: August 5th, 2021, 9:02 am
by Country_Bubba
I am guessing here, but the model may be to big for the build platform. Looking at the front edge, it appears to be in the "no print zone"
Maybe you can move it back some? The model can not be in the gray shaded area of the bed outline. This area is affected by your settings which might make this area smaller.
HTH
Posted: August 5th, 2021, 11:52 am
by andzbro
da die der körper jedoch 300x300 ist und die druckfläche auch genau 300x300 beträgt ist das ein rate spiel wie weit ich das stück nach hinten/vorne setzen muss^^
Posted: August 5th, 2021, 12:34 pm
by Country_Bubba
Yes, your print bed is 300x300, but the print area will not necessarily allow a print that big. Cura automatically reduces the print area size by an amount to allow for skirts, brims, rafts etc. If you look as your graphic closely, you can see a grey shaded area around the perimeter of the bed. This is a no print zone and if your model goes into this area, it will not allow slicing.
Posted: August 5th, 2021, 12:40 pm
by andzbro
@ Country_Bubba das war auch meine befürchtung. ich habe nur erhoft das es nur ein "ausrichtungs" problem sei. ich danke dir dan muss ich es neu zeichnen in 280 oder 290mm breite q.q
brauche den genauen zwischen abstand da kan ich leider nicht die zeichnung einfach in 99% oder 98% skalieren-
Posted: August 5th, 2021, 11:12 pm
I sure wish he'd use Google Translate and post in English
Posted: August 6th, 2021, 9:47 am
by Country_Bubba
yeh, especially when I tried to put the error message into translate with my English keyboard! Fortunately it was close enough for me to confirm my suspicion of what was wrong:})
