Problem with raised letters
maggiolo72
3D Printer(s): LK1
Post by maggiolo72 »
I try to print a part with raised letters on top, but after the slice some letters are missing.
I printed with cura 4.12.1 the part and the letters are missing like the preview, this doesn't happens with Ideamaker.
I have the same issue with others part from the same project.
There are some settings that I can do for make the things better ?
The .stl file is attached.
Thank you very much
UFC Body Modified - raised text -IB.stl
(1.37 MiB) Downloaded 519 times
Re: Problem with raised letters
Try slicing it with a smaller nozzle size Those are pretty small letters
