I had written a post about how much I dislike the SN04 and what a PITA it is to have to re-zero it every print lest I get bed crashes/scratches and how I want to put a BL Touch on and that I need help....but there's already a post exactly for that. Instead I'll ask the second part of that post: what hardware upgrades should I really, really do? Minus the extruder fan, belt tensioners, and a cable chain, it's a pretty stock unit - don't think I've even upgraded the firmware.
I strongly dislike the aluminum bed (which is probably warped) and that I have to use blue tape on it *almost* as much as I dislike the inductive sensor. I could see myself adding a new bed with a flat build surface - glass, magnetic/removeable, ultrabase, whatever...
I'm up for whatever. I want to play around with the firmware, install the BL Touch, new bed/build surface, maybe a new extruder, motor drivers, etc...
3DP-11/12 Go nuts upgrades
Jump to
- Announcements
- ↳ News and Announcements
- 3D Printers
- ↳ General / RepRap Printers
- ↳ HICTOP RepRap Prusa I3
- ↳ Hardware Modifications
- ↳ General Questions
- ↳ Large Scale 3D Printers
- ↳ Tevo brand 3D Printers
- ↳ Resin 3D Printers
- ↳ Micro 3D Printers
- Ultimaker Printers
- ↳ Ultimaker S5
- ↳ General Discussion
- ↳ Special brand filaments
- Getting better prints!
- ↳ Help me fix this print!
- Software & Electronics
- ↳ Slicers and CAD Software
- ↳ Cura
- ↳ Simplify 3D
- ↳ Other Slicing programs
- ↳ Slic3r
- ↳ Electronics
- ↳ Firmware
- ↳ Firmware
- General
- ↳ Off Topics!
- ↳ The MarketPlace
- Modders Kiosk
