Cura Setting, Stops extrusion too early
NikNakPaddywagg
Post by NikNakPaddywagg »
Hello Community,
I tried hard to find a Solutionbut I dont know wich setting I have to tweak to get rid of the following Problem. At the End of each area of a layer the Extrusion stopps too early. I uploaded a picture of the Problem.
I hope someone can help me.
Thank you.
Re: Cura Setting, Stops extrusion too early
Check if you have Coasting enabled
I would also check to see if infill/perimeters overlap by 25%
