Page 1 of 4
How to Attach Photos
Posted: February 11th, 2016, 11:42 pm
Inserting a picture is different that most of the forum software packages out there.
However, it is pretty easy and I have made plenty of space available on the server for local storage.
First, if you are
making a new post, you are in the "Full Editor and Preview" editor. If you are
replying in the Quick Reply, you need to click "Full Editor and Preview" This is where, at the bottom of the screen, is the "Options", "Attachments" and "Poll Creation" tabs.
- Capture.JPG (17.15 KiB) Viewed 21643 times
Click the "Attachments" and you will see the "Add File"
The file box will appear on your computer screen and ask where the file is you wish to attach.
Once the file has been uploaded, you will see the filename, an option to "Place inline", "Delete File", "File Comment", "Size" and "Status"
Filename is self-explanatory
"Place inline" will place the link to the attachment in the body of your post
"Delete file" deletes the file you uploaded
"Size" shows you the size of your file
"Status", if Green, means the file was received and is OK.
From here you can click the "Options" tab if there are any items you wish to check off, such as 'Notify me when a reply is posted'
You can also click "Preview" to see how the attachments look prior to hitting "Submit" to post.
That's it!
Re: How to Attach Photos
Posted: February 25th, 2016, 9:31 am
by Chip Luck
Looks like I still cannot get photos to post to message. They do upload, but I never get the STATUS green or Place Inline tab option. Is there a maximum size?
Cheers,
Chip
Posted: February 25th, 2016, 10:12 am
by Amedee
If the file is too big it will tell you upfront.
Which browser are you using?
(Internet explorer not a good answer
Posted: February 25th, 2016, 10:15 am
by Chip Luck
Firefox - latest version. Win7 64bit Ultimate. Have no issues on other sites/forums. I used to run this forum software years ago, at least I'm glad it's still around.
IE are you kidding me? Actually I boot into Ubuntu Linux most of the time for development work, hate Winblows...
Chip
Posted: February 25th, 2016, 10:16 am
Size limit is 5mb per file...which is petty darn huge for an image file.
Best success with anything non Microsoft. Firefox, Chrome or if you like Peppermint (Linux) as i do, Chromium works nicely
Posted: February 25th, 2016, 10:19 am
by Chip Luck
As mentioned, I dual boot into Ubuntu Linux that I use for all my development work. Winblow's should still work as I have no issues with other boards/forums. I checked the file sizes and they are under 5mb, but the uploader should warn of too large a size I would assume?
Will clear cache's and Firefox and try again...
Posted: February 25th, 2016, 10:23 am
Please let us know...there's tons of pictures uploaded here, so it should work without much hassle
by Amedee
Very strange, I tried here to upload bad things (too big, wrong extensions, ...) and either it works or it tells you it is not valid...
Any suspicious plugin (ad-blocker, ...) or anti-virus in place?
Posted: February 25th, 2016, 10:40 am
by Chip Luck
The status bar goes all the way to full green during upload of a 1.4mb .jpg. Then it just sits there, not status light and no post in-line. I also tried dragging the file to message - it uploads, but then again once the status bar is done 'uploading' it just sits there. Interesting.
Of course I have anti-virus, should have nothing to do with upload of a image file. Again, other forums = no problem. Also cleared out Firefox and this sites cookies, cache, et all. Still same issue.
Posted: February 25th, 2016, 10:48 am
Posted: February 25th, 2016, 10:57 am
I am unable to duplicate the error you are having
Posted: February 25th, 2016, 11:00 am
by martin-bienz
I had the same issue yesterday when I tried to upload the 2.4MB Original UM (cutout) of yours, so I zipp'd it and all was ok. I just thought that maybe 2.4 MB was to large... maybe try another, shorter name? Was it a png? My File was a png... maybe something to do with the mime type?
Posted: February 25th, 2016, 11:05 am
by Amedee
Chip Luck wrote:Of course I have anti-virus, should have nothing to do with upload of a image file.
No it should not...
... but some are very invasive and filter all your http content.
I used to run a relative big forum and I got the case once where some scripts were not running, and the anti-virus was the culprit...
So my questions/suggestions may seem stupid, but I have really seen a lot of edge cases...
I can myself load files up to 5M, without issues -- takes just a few seconds.
If you have a bit of experience with the "Developper's panel" from Firefox, you can check what happens with the upload on your side.
As you can see it is just a JSON POST request with the file in the payload -- there is no black magic it is posted in a single call. It would be interesting to see if that call finishes on your side or exits / times out with an error.
Posted: February 25th, 2016, 11:08 am
martin-bienz wrote:I had the same issue yesterday when I tried to upload the 2.4MB Original UM (cutout) of yours, so I zipp'd it and all was ok. I just thought that maybe 2.4 MB was to large... maybe try another, shorter name? Was it a png? My File was a png... maybe something to do with the mime type?
I'll check the attachment extensions now
Posted: February 25th, 2016, 11:10 am
Ok, no issue on the phpBB, the image settings know GIF, JPG, PNG, JPEG, TGA, TIF and TIFF are image formats.
