Cura 2.1.3 is out
Posted: August 16th, 2016, 9:40 am
Not seeing any mention of the autoscale being altered in this build...
Cura 2.1.3
Cura 2.1.3 - August 16, 2016
New material profiles for CPE+, PC, Nylon and TPU 95A for the Ultimaker 2+ family.
Fixed an issue where a raft goes outside the print area.
Fixed a bug where rafts overlap in the one-at-a-time mode.
Fixed a bug in the gantry height for the Ultimaker 2, Ultimaker 2 Extended and Ultimaker 2 Go machines.
New Firmware
Fixed an issue where printers from the Ultimaker 2 and Ultimaker 2+ families occasionally hit the right side of the machine or the glass retainer clips during printing.
The maximum bed temperature increased from 100 °C to 115 °C for the Ultimaker Original+, Ultimaker Original (with the Heated Bed upgrade kit), Ultimaker 2+ and Ultimaker 2 Extended+ printers.
Added an option to specify retraction settings per material and per nozzle for the Ultimaker 2+ family.
During the heating phase of the 3D printer, the heated bed is positioned as far away from the nozzle as possible for safety reasons.
Improved the material change procedure to ensure that the nozzle temperature always matches the requirements of the to-be-loaded filament.
Cura 2.1.3
New Firmware
