DNS Problems
- Meduza
DNS Problems
I have had quite a lot of problems accessing this new forum some times since the DNS cannot always resolve the domain properly. I'll would guess that something is not configured correctly.
Re: DNS Problems
Hi
Two changes.
1) Static IP now. GoDaddy had it on a shared / rotating one.
2) Just modified the Host @ record and set TTL to 60 minutes, up from 10 minutes.
Please let me know if these changes make things better
Two changes.
Re: DNS Problems
The situation seems to have improved since you made the changes. These are the only two DNS outages that I could detect since then:
Sat Feb 13 2016 19:55:01-20:02:01
Sun Feb 14 2016 08:22:01-08:25:02
Before the change it was much more. I think you could even increase the TTL to the default of 86400s (1 day) if you do not plan any server migrations in the near future.
Re: DNS Problems
That I can do...I don't plan to make any moves!
Re: DNS Problems
It has been working fine here both yesterday and today, so the changes appears to have helped.
Re: DNS Problems
That's excellent news, thank you
