http://octoprint.org/blog/2017/07/05/ne ... se-0-14-0/
Changes in the image
Added note to /root/bin/webcamd to use octopi.txt for configuration
Added note to octopi-network.txt for Mac OS X users to not use Textedit/properly configure Textedit
Added note with further instructions on usage to boot and login screen
Allow configuration of multiple wifi networks via octopi-wpa-supplicant.txt
Better “service not running” error pages
Enabled SSH by default (we usually run headless, disabling it is not an option)
Updated stock config.yaml and init script for OctoPrint to 1.3.0+
Updated install-desktop script to only pull in needed packages
Fixes:
Prevent NTP updates from failing on RPi3 wifi (#327)
Prevent weird SSH issues on RPi3 (#294)
Prevent duplicate X-Scheme headers in haproxy (#239)
Workaround for an issue with recent pip versions and pyasn1 (#276)
Changes in the build scripts
Support for building against Armbian
Support for custom number for root partition
Fixed pybonjour download link (google code is dead)
Switched vagrant box to one including guest additions
The full release notes can be found at github.
You can download OctoPi 0.14.0 from the usual places. If you are asking yourself how to update from an earlier version of OctoPi, please read on.
New Release!
Re: New Release!
I finally got my pi's setup (what is the plural for Octopi - so confused). Little-hicci for the 3DP-17, big-hicci for the CR-10S.
Now I am having 90's flashbacks. What's with the 8.3 file names only?
I'm looking at both Marlin and Octoprint for solutions here. I find it odd that I get at least 40 characters (display width) on the printer displays.
Re: New Release!
Also, why does it print so slow? Need to look into that. May be worth the time to have Octopi download to SD and then print.
Re: New Release!
Well if you look at the baud rate versus what could be done via the SD card...
But it's the convenience factor.
Re: New Release!
Need to revisit this post with some updates (for those that are following along):
Turns out, the Marlin firmware only outputs in 8.3 format. See https://github.com/foosel/OctoPrint/issues/1600.What's with the 8.3 file names only?
Actually, it only reports that it is printing much slower, if you look at the "Approx. Total Print Time:" in the sidebar "State" section. If you look at the GCode Viewer tab, you will get an estimate that is much closer to Cura's est printing time.Also, why does it print so slow? Need to look into that. May be worth the time to have Octopi download to SD and then print.
