School is back in session here! (I work at a University so week one was super busy)
How is everyone?
How is everyone?
I'm loving the Rivyt webpage system for YouTubers...check this out
http://wherenerdyiscool.rivyt.com/
Well I decided to redirect my WhereNerdyIsCool.com site to rivyt I really like their service...and it saves me from messing with Wordpress
- jonnybischof
That link doesn't work anymore btw.LePaul wrote: ↑September 7th, 2017, 1:20 pm I'm loving the Rivyt webpage system for YouTubers...check this out
www.WhereNerdyIsCool.com does.
It's a simple but cool page! Not too much clutter and stuff you have to care about, only content.
Yes that old link won't work since the name settings/Dns stuff took effect.
- Titus
Interesting:
https://i.imgur.com/tmkcTwU.jpg
Not quite what I expected. Especially not the, from what it seems, different sanding directions?
Change default speed to avoid overheating the print. It’s hidden inside speed settings
- Titus
It was 20 mm/s, which I couldn't image to be right(I'm printing at 60 mm/s), so I changed it to 60 mm/s too. Do you recon I should go even faster for the Neosanding speed?
Yea. Faster. For 50-60 I do 100mm/s sanding
Slower only helps if your top layers show too many gaps on the top layer surface. Fast will leave a nice look and you can increase the passes without loosing much time
I've been meaning to try out that feature
- Titus
https://ultimaker.com/en/blog/51255-com ... e-releases
Not sure who or where someone hinted at something upcoming, might be this.
I thought we might have a new machine coming up
And I was wondering why all the sudden there are random non-consistent underextrusions...
I have from time to time when using multiple Slicers mess up My 3D Printer Marlin Firmware (I know most are using Teacup).shurik
Just Yesterday I Was Testing to see which of the Slicers would Allow me to send G-Code to the Printer.
When I started printing a Model it looked like Swish Cheese See Image.
Some how just by connecting and sending a couple of G-codes (for testing purposes) I mess up the Printer Filament Size.
And until I had sent a M502 and M500 every print looked the swish cheese.
Maybe something like this could have happened.
