Updating Stock HICTOP 3DP-11-ATL to Latest Marlin and Changing Bed Leveling Sensor
kgrigio
3D Printer(s): HICTOP 3DP-11-ATL
Post by kgrigio »
I have been going the rounds trying to get the stock HICTOP 3DP-11-ATL firmware upgraded to the latest marlin and am really struggling and am not seeing what I am doing wrong. To add in a twist, I am also replacing the stock inductive auto-bed leveling sensor with a mini differential IR sensor. That change over seems pretty straight forward, just invert the Z_MIN_ENDSTOP input, but my problem is going with the first change, from the stock firmware to the latest Marlin.
I have read through a lot of posts here and have tried taking some of the configuration.h files that I am finding here, but everytime I compile and upload to my printer, my LCD display is either blank or shows a bunch of garbage and I have to put the stock firmware back on.
What more do I have to change besides the configuration.h file?
Thanks for any help in advance.
Re: Updating Stock HICTOP 3DP-11-ATL to Latest Marlin and Changing Bed Leveling Sensor
Hello:
I have Helped many with this upgrade, I have preformed upgrade to most of the Marlin 1.1.X firmware.
What version are you wanting to upgrade to. What are all the changes you have made.
Post your changes so far I will take a look an let you know what I have found.
State what you want on the finished firmware, Filament run out sensor, bed leveling ect....
kgrigio
Post by kgrigio »
There are two things that I am trying to do, first I am trying to update the stock HICTOP 3DP-11-ATL firmware, posted here
Marlin_3DP08-12-398_Original FW from HICTOP.rar
(190.29 KiB) Downloaded 1314 times
to the latest Marlin that I got off GitHub here
https://github.com/MarlinFirmware/Marlin.git
I went through the two configuration.h files and tried to update as best as I could. Here is a copy of my configuration.h file
Configuration.h
(62.73 KiB) Downloaded 1188 times
My printer has the stock HICTOP inductive auto-bed leveling sensor, found here
All I did was change the configuration.h file and everything compiled in Arduino 1.8.5 and I uploaded to my printer. After rebooting my printer after the firmware update, this is what I get on my display.
For now, all I want to do is get my stock firmware working in the latest marlin software.
After I get that working, I want to get my new IR differential sensor working to replace my inductive proximity sensor. The IR sensor information can be found here.
https://miscsolutions.wordpress.com/min ... sor-board/
and the information about what I need to do in the firmware to get it working was emailed to me by the seller of the sensor.
1. Connect the IR sensor in place of the previous proximity sensor - except that your old proximity sensor may have needed a 12V supply; whereas the IR sensor needs only 3.3V or 5V, which is available from the 3rd pin of the endstop connector on most controller electronics.
2. In the firmware for your controller electronics, make sure that the pullup resistor on the input that the sensor is connected is enabled. Then the LED on the sensor should flash twice a few seconds after power up. If it flashes 4 times, then the pullup resistor is not enabled.
3. The IR sensor produces an active high output. If your previous proximity sensor had an active low output (e.g. NPN inductive sensor), then you will need to invert the sense of the Z probe input, which is another firmware configuration setting.
4. Measure the trigger height and configure that value in your firmware.
I believe point 1 and 2 are already done because when I hook up the IR sensor in place of the place of the inductive sensor I see the two led flashes. The next step is to change invert the Z probe input. I think to do this I need to change the following in the configuration.h file
#define X_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop.
#define Y_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop.
//#define Z_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop.
#define Z_MIN_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop.
#define X_MAX_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop.
#define Y_MAX_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop.
#define Z_MAX_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop.
//#define Z_MIN_PROBE_ENDSTOP_INVERTING false // set to true to invert the logic of the probe.
#define Z_MIN_PROBE_ENDSTOP_INVERTING true // set to true to invert the logic of the probe.
I can't test this theory however because I can't get past the first step of updating the firmware from the stock firmware to the latest marlin.
I hope this is all clear and explains the situation. Thanks for any help.
kgrigio
Post by kgrigio »
In reading through the following thread
viewtopic.php?f=51&t=189&start=105#p8551
I found firmware referenced by shocksofmighty that I downloaded and compiled. My printer appears to be working now. What version of Marlin is this firmware?
I will try using this base fireware to add in my differential IR sensor and see how it turns out.
Had to work late.
I see that you have not enabled the Display
This display has to be enabled to work the stock display for Hictop
//#define REPRAP_DISCOUNT_SMART_CONTROLLER
Will look deeper When Not so Tried.
I have Marlin 1.1.5 working On my machines If you want It.
kgrigio
Post by kgrigio »
Thanks. Part of learning this stuff is knowing what to turn off and on, so I appreciate the help. I will take you Marlin 1.1.5 when you get a chance. Thanks again!
Attached is Marlin-kgrigio this needs to me extracted to folder Marlin-kgrigio
It is setup for Bed Leveling, Baby Steps, Individual Axis menu Home.
Archived with 7-Zip
Marlin-kgrigio.7z
(462.67 KiB) Downloaded 1180 times
Changed the name from Dave to kgrigio
Sent this to Dave in the UK said it worked perfect, but you should still proceed carefully with any firmware upgrade.
This is setup for a T8-8 (8mm pitch) lead screw though I have setups for All below
// Z Axis 3200, / 1.25mm pitch leadscrew = 200*16 /1.25 = 2560 :: (STEPS_PER_REVOLUTION_Z / PITCH_OF_Z_ROD)
// Z Axis 3200, / 2mm pitch leadscrew = 200*16 /2 = 1600 :: (STEPS_PER_REVOLUTION_Z / PITCH_OF_Z_ROD)
// Z Axis 3200, / 4mm pitch leadscrew = 200*16 /4 = 800 :: (STEPS_PER_REVOLUTION_Z / PITCH_OF_Z_ROD)
// Z Axis 3200, / 8mm pitch leadscrew = 200*16 /8 = 400 :: (STEPS_PER_REVOLUTION_Z / PITCH_OF_Z_ROD)
Have any questions just Post.
kgrigio
Post by kgrigio »
Thanks. I will give this a try tomorrow. I have the threaded rod in my setup so will need to figure change that piece, but other than that, I should be good to go and I will let you know how it works out.
kgrigio
Post by kgrigio »
I was able to download your file and test it out with the stock inductive sensor. I made some tweaks to it based off the .rar file I got above, but in the end, it seems to be working just great. Thanks for the help. Now to play with getting my IR differential sensor working. Once I get it working with that sensor, I will come back and post my changes.
kgrigio
Post by kgrigio »
Where in the code is the definition around homing? I can't find what file the sequence is in. In my previous firmware, the homing went to x_min, then y_min, then z_min then to the center of the build plate. In the 1.1.5 version the z_min is done after centering the build plate. I am just curious where this sequence is located because I am not finding it, which leads to another question. Is there a way to do a search across all the files in the folder? I tried searching for homing in the configuration.h and configuration_adv.h files and didn't see the homing sequence, but to search every file one at a time would be nuts.
If you are using the zip file I posted
It appears that these lines have been Changed
Notes wrote: //#define Z_SAFE_HOMING
#if ENABLED(Z_SAFE_HOMING)
#define Z_SAFE_HOMING_X_POINT X10 // X point for Z homing when homing all axis (G28).
#define Z_SAFE_HOMING_Y_POINT Y10 // Y point for Z homing when homing all axis (G28).
#endif
Replace with the Original lines to restore the original Z safe Homing lines.
This will allow you to home center bed (Almost)
Notes wrote: #define Z_SAFE_HOMING
#define Z_SAFE_HOMING_X_POINT ((X_MIN_POS + X_MAX_POS) / 2) // Z homing when homing all axis (G28). ((X_MIN_POS + X_MAX_POS) / 2)
#define Z_SAFE_HOMING_Y_POINT ((Y_MIN_POS + Y_MAX_POS) / 2) // Z homing when homing all axis (G28). ((Y_MIN_POS + Y_MAX_POS) / 2)
#endif
kgrigio
Post by kgrigio »
Thanks for all the help. I have spent a lot of time this week really diving into how the firmware works. I was able to get the firmware working with the stock inductive sensor and then installed the mini IR differential sensor. It took a bit of tuning and tweaking, but I love the IR sensor. It allows me to print over glass. I will copy my Configuration.h file below for reference. I had to print a mount for the sensor that I will be putting into thingyverse and will link to that in a bit.
The issue I am fighting with now is my bed leveling, which version to use and is it working the way it should, but I will start another thread on that.
Code: Select all
 * Marlin 3D Printer Firmware
 * Configuration.h
#ifndef CONFIGURATION_H
#define CONFIGURATION_H
#define CONFIGURATION_H_VERSION 010100
// @section info
#define STRING_CONFIG_H_AUTHOR "(kgrigio_B-Steps)"     // Who made the changes.
#define SHOW_BOOTSCREEN
#define STRING_SPLASH_LINE1 SHORT_BUILD_VERSION // will be shown during bootup in line 1
#define STRING_SPLASH_LINE2 WEBSITE_URL         // will be shown during bootup in line 2
// @section machine
 * Select which serial port on the board will be used for communication with the host.
 * This allows the connection of wireless adapters (for instance) to non-default port pins.
 * Serial port 0 is always used by the Arduino bootloader regardless of this setting.
 * :[0, 1, 2, 3, 4, 5, 6, 7]
#define SERIAL_PORT 0
 * This setting determines the communication speed of the printer.
 * 250000 works in most cases, but you might try a lower speed if
 * you commonly experience drop-outs during host printing.
 * :[2400, 9600, 19200, 38400, 57600, 115200, 250000]
#define BAUDRATE 115200
// Enable the Bluetooth serial interface on AT90USB devices
//#define BLUETOOTH
// The following define selects which electronics board you have.
// Please choose the name from boards.h that matches your setup
#ifndef MOTHERBOARD
  #define MOTHERBOARD BOARD_RAMPS_14_EFB
#endif
// Optional custom name for your RepStrap or other custom machine
// Displayed in the LCD "Ready" message
#define CUSTOM_MACHINE_NAME "Hic-3DP"
// Define this to set a unique identifier for this printer, (Used by some programs to differentiate between machines)
// You can use an online service to generate a random UUID. (eg http://www.uuidgenerator.net/version4)
//#define MACHINE_UUID "00000000-0000-0000-0000-000000000000"
// @section extruder
// This defines the number of extruders
// :[1, 2, 3, 4, 5]
#define EXTRUDERS 1
// For Cyclops or any "multi-extruder" that shares a single nozzle.
//#define SINGLENOZZLE
 * Průša MK2 Single Nozzle Multi-Material Multiplexer, and variants.
 * This device allows one stepper driver on a control board to drive
 * two to eight stepper motors, one at a time, in a manner suitable
 * for extruders.
 * This option only allows the multiplexer to switch on tool-change.
 * Additional options to configure custom E moves are pending.
//#define MK2_MULTIPLEXER
#if ENABLED(MK2_MULTIPLEXER)
  // Override the default DIO selector pins here, if needed.
  // Some pins files may provide defaults for these pins.
  //#define E_MUX0_PIN 40  // Always Required
  //#define E_MUX1_PIN 42  // Needed for 3 to 8 steppers
  //#define E_MUX2_PIN 44  // Needed for 5 to 8 steppers
#endif
// A dual extruder that uses a single stepper motor
//#define SWITCHING_EXTRUDER
#if ENABLED(SWITCHING_EXTRUDER)
  #define SWITCHING_EXTRUDER_SERVO_NR 0
  #define SWITCHING_EXTRUDER_SERVO_ANGLES { 0, 90 } // Angles for E0, E1[, E2, E3]
  #if EXTRUDERS > 3
    #define SWITCHING_EXTRUDER_E23_SERVO_NR 1
  #endif
#endif
// A dual-nozzle that uses a servomotor to raise/lower one of the nozzles
//#define SWITCHING_NOZZLE
#if ENABLED(SWITCHING_NOZZLE)
  #define SWITCHING_NOZZLE_SERVO_NR 0
  #define SWITCHING_NOZZLE_SERVO_ANGLES { 0, 90 }   // Angles for E0, E1
  //#define HOTEND_OFFSET_Z { 0.0, 0.0 }
#endif
 * Two separate X-carriages with extruders that connect to a moving part
 * via a magnetic docking mechanism. Requires SOL1_PIN and SOL2_PIN.
//#define PARKING_EXTRUDER
#if ENABLED(PARKING_EXTRUDER)
  #define PARKING_EXTRUDER_SOLENOIDS_INVERT           // If enabled, the solenoid not magnetized with applied voltage
  #define PARKING_EXTRUDER_SOLENOIDS_PINS_ACTIVE LOW  // LOW or HIGH pin signal energizes the coil
  #define PARKING_EXTRUDER_SOLENOIDS_DELAY 250        // Delay (ms) for magnetic field. No delay if 0 or not defined.
  #define PARKING_EXTRUDER_PARKING_X { -78, 184 }     // X positions for parking the extruders
  #define PARKING_EXTRUDER_GRAB_DISTANCE 1            // mm to move beyond the parking point to grab the extruder
  #define PARKING_EXTRUDER_SECURITY_RAISE 5           // Z-raise before parking
  #define HOTEND_OFFSET_Z { 0.0, 1.3 }                // Z-offsets of the two hotends. The first must be 0.
#endif
 * "Mixing Extruder"
 *   - Adds a new code, M165, to set the current mix factors.
 *   - Extends the stepping routines to move multiple steppers in proportion to the mix.
 *   - Optional support for Repetier Firmware M163, M164, and virtual extruder.
 *   - This implementation supports only a single extruder.
 *   - Enable DIRECT_MIXING_IN_G1 for Pia Taubert's reference implementation
//#define MIXING_EXTRUDER
#if ENABLED(MIXING_EXTRUDER)
  #define MIXING_STEPPERS 2        // Number of steppers in your mixing extruder
  #define MIXING_VIRTUAL_TOOLS 16  // Use the Virtual Tool method with M163 and M164
  //#define DIRECT_MIXING_IN_G1    // Allow ABCDHI mix factors in G1 movement commands
#endif
// Offset of the extruders (uncomment if using more than one and relying on firmware to position when changing).
// The offset has to be X=0, Y=0 for the extruder 0 hotend (default extruder).
// For the other hotends it is their distance from the extruder 0 hotend.
//#define HOTEND_OFFSET_X {0.0, 20.00} // (in mm) for each extruder, offset of the hotend on the X axis
//#define HOTEND_OFFSET_Y {0.0, 5.00}  // (in mm) for each extruder, offset of the hotend on the Y axis
// @section machine
 * Select your power supply here. Use 0 if you haven't connected the PS_ON_PIN
 * 0 = No Power Switch
 * 1 = ATX
 * 2 = X-Box 360 203Watts (the blue wire connected to PS_ON and the red wire to VCC)
 * :{ 0:'No power switch', 1:'ATX', 2:'X-Box 360' }
#define POWER_SUPPLY 1
#if POWER_SUPPLY > 0
  // Enable this option to leave the PSU off at startup.
  // Power to steppers and heaters will need to be turned on with M80.
  //#define PS_DEFAULT_OFF
#endif
// @section temperature
//============================= Thermal Settings ============================
* Temperature sensors available:
 *    -3 : thermocouple with MAX31855 (only for sensor 0)
 *    -2 : thermocouple with MAX6675 (only for sensor 0)
 *    -1 : thermocouple with AD595
 *     0 : not used
 *     1 : 100k thermistor - best choice for EPCOS 100k (4.7k pullup)
#define TEMP_SENSOR_0 1
#define TEMP_SENSOR_1 0
#define TEMP_SENSOR_2 0
#define TEMP_SENSOR_3 0
#define TEMP_SENSOR_4 0
#define TEMP_SENSOR_BED 1
// Dummy thermistor constant temperature readings, for use with 998 and 999
#define DUMMY_THERMISTOR_998_VALUE 25
#define DUMMY_THERMISTOR_999_VALUE 100
// Use temp sensor 1 as a redundant sensor with sensor 0. If the readings
// from the two sensors differ too much the print will be aborted.
//#define TEMP_SENSOR_1_AS_REDUNDANT
#define MAX_REDUNDANT_TEMP_SENSOR_DIFF 10
// Extruder temperature must be close to target for this long before M109 returns success
#define TEMP_RESIDENCY_TIME 10  // (seconds)
#define TEMP_HYSTERESIS 3       // (degC) range of +/- temperatures considered "close" to the target one
#define TEMP_WINDOW     1       // (degC) Window around target to start the residency timer x degC early.
// Bed temperature must be close to target for this long before M190 returns success
#define TEMP_BED_RESIDENCY_TIME 10  // (seconds)
#define TEMP_BED_HYSTERESIS 3       // (degC) range of +/- temperatures considered "close" to the target one
#define TEMP_BED_WINDOW     1       // (degC) Window around target to start the residency timer x degC early.
// The minimal temperature defines the temperature below which the heater will not be enabled It is used
// to check that the wiring to the thermistor is not broken.
// Otherwise this would lead to the heater being powered on all the time.
#define HEATER_0_MINTEMP 5
#define HEATER_1_MINTEMP 5
#define HEATER_2_MINTEMP 5
#define HEATER_3_MINTEMP 5
#define HEATER_4_MINTEMP 5
#define BED_MINTEMP 5
// When temperature exceeds max temp, your heater will be switched off.
// This feature exists to protect your hotend from overheating accidentally, but *NOT* from thermistor short/failure!
// You should use MINTEMP for thermistor short/failure protection.
#define HEATER_0_MAXTEMP 260
#define HEATER_1_MAXTEMP 260
#define HEATER_2_MAXTEMP 260
#define HEATER_3_MAXTEMP 260
#define HEATER_4_MAXTEMP 260
#define BED_MAXTEMP 150
//============================= PID Settings ================================
// PID Tuning Guide here: http://reprap.org/wiki/PID_Tuning
// Comment the following line to disable PID and enable bang-bang.
#define PIDTEMP
#define BANG_MAX 255 // limits current to nozzle while in bang-bang mode; 255=full current
#define PID_MAX BANG_MAX // limits current to nozzle while PID is active (see PID_FUNCTIONAL_RANGE below); 255=full current
#if ENABLED(PIDTEMP)
  //#define PID_AUTOTUNE_MENU // Add PID Autotune to the LCD "Temperature" menu to run M303 and apply the result.
  //#define PID_DEBUG // Sends debug data to the serial port.
  //#define PID_OPENLOOP 1 // Puts PID in open loop. M104/M140 sets the output power from 0 to PID_MAX
  //#define SLOW_PWM_HEATERS // PWM with very low frequency (roughly 0.125Hz=8s) and minimum state time of approximately 1s useful for heaters driven by a relay
  //#define PID_PARAMS_PER_HOTEND // Uses separate PID parameters for each extruder (useful for mismatched extruders)
                                  // Set/get with gcode: M301 E[extruder number, 0-2]
  #define PID_FUNCTIONAL_RANGE 10 // If the temperature difference between the target temperature and the actual temperature
                                  // is more than PID_FUNCTIONAL_RANGE then the PID will be shut off and the heater will be set to min/max.
  #define K1 0.95 //smoothing factor within the PID
  // If you are using a pre-configured hotend then you can use one of the value sets by uncommenting it
  // Ultimaker
  //Hic 3DP-12
  #define  DEFAULT_Kp 17.22
  #define  DEFAULT_Ki 0.89
  #define  DEFAULT_Kd 83.25
// Defaults
//  #define  DEFAULT_Kp 22.2
//  #define  DEFAULT_Ki 1.08
//  #define  DEFAULT_Kd 114
  // MakerGear
  //#define  DEFAULT_Kp 7.0
  //#define  DEFAULT_Ki 0.1
  //#define  DEFAULT_Kd 12
  // Mendel Parts V9 on 12V
  //#define  DEFAULT_Kp 63.0
  //#define  DEFAULT_Ki 2.25
  //#define  DEFAULT_Kd 440
#endif // PIDTEMP
//============================= PID > Bed Temperature Control ===============
// Select PID or bang-bang with PIDTEMPBED. If bang-bang, BED_LIMIT_SWITCHING will enable hysteresis
// Uncomment this to enable PID on the bed. It uses the same frequency PWM as the extruder.
// If your PID_dT is the default, and correct for your hardware/configuration, that means 7.689Hz,
// which is fine for driving a square wave into a resistive load and does not significantly impact you FET heating.
// This also works fine on a Fotek SSR-10DA Solid State Relay into a 250W heater.
// If your configuration is significantly different than this and you don't understand the issues involved, you probably
// shouldn't use bed PID until someone else verifies your hardware works.
// If this is enabled, find your own PID constants below.
//#define PIDTEMPBED
//#define BED_LIMIT_SWITCHING
// This sets the max power delivered to the bed, and replaces the HEATER_BED_DUTY_CYCLE_DIVIDER option.
// all forms of bed control obey this (PID, bang-bang, bang-bang with hysteresis)
// setting this to anything other than 255 enables a form of PWM to the bed just like HEATER_BED_DUTY_CYCLE_DIVIDER did,
// so you shouldn't use it unless you are OK with PWM on your bed.  (see the comment on enabling PIDTEMPBED)
#define MAX_BED_POWER 255 // limits duty cycle to bed; 255=full current
#if ENABLED(PIDTEMPBED)
  //#define PID_BED_DEBUG // Sends debug data to the serial port.
  //120V 250W silicone heater into 4mm borosilicate (MendelMax 1.5+)
  //from FOPDT model - kp=.39 Tp=405 Tdead=66, Tc set to 79.2, aggressive factor of .15 (vs .1, 1, 10)
  #define  DEFAULT_bedKp 10.00
  #define  DEFAULT_bedKi .023
  #define  DEFAULT_bedKd 305.4
  //from pidautotune
  //#define  DEFAULT_bedKp 97.1
  //#define  DEFAULT_bedKi 1.41
  //#define  DEFAULT_bedKd 1675.16
  // FIND YOUR OWN: "M303 E-1 C8 S90" to run autotune on the bed at 90 degreesC for 8 cycles.
#endif // PIDTEMPBED
// This option prevents extrusion if the temperature is below EXTRUDE_MINTEMP.
// It also enables the M302 command to set the minimum extrusion temperature
// or to allow moving the extruder regardless of the hotend temperature.
// *** IT IS HIGHLY RECOMMENDED TO LEAVE THIS OPTION ENABLED! ***
#define PREVENT_COLD_EXTRUSION
#define EXTRUDE_MINTEMP 170
// This option prevents a single extrusion longer than EXTRUDE_MAXLENGTH.
// Note that for Bowden Extruders a too-small value here may prevent loading.
#define PREVENT_LENGTHY_EXTRUDE
#define EXTRUDE_MAXLENGTH 100
//======================== Thermal Runaway Protection =======================
 * Thermal Protection protects your printer from damage and fire if a
 * thermistor falls out or temperature sensors fail in any way.
 * The issue: If a thermistor falls out or a temperature sensor fails,
 * Marlin can no longer sense the actual temperature. Since a disconnected
 * thermistor reads as a low temperature, the firmware will keep the heater on.
 * If you get "Thermal Runaway" or "Heating failed" errors the
 * details can be tuned in Configuration_adv.h
#define THERMAL_PROTECTION_HOTENDS // Enable thermal protection for all extruders
#define THERMAL_PROTECTION_BED     // Enable thermal protection for the heated bed
//============================= Mechanical Settings =========================
// @section machine
// Uncomment one of these options to enable CoreXY, CoreXZ, or CoreYZ kinematics
// either in the usual order or reversed
//#define COREXY
//#define COREXZ
//#define COREYZ
//#define COREYX
//#define COREZX
//#define COREZY
//============================== Endstop Settings ===========================
// @section homing
// Specify here all the endstop connectors that are connected to any endstop or probe.
// Almost all printers will be using one per axis. Probes will use one or more of the
// extra connectors. Leave undefined any used for non-endstop and non-probe purposes.
#define USE_XMIN_PLUG
#define USE_YMIN_PLUG
#define USE_ZMIN_PLUG
//#define USE_XMAX_PLUG
//#define USE_YMAX_PLUG
#define USE_ZMAX_PLUG
// coarse Endstop Settings
#define ENDSTOPPULLUPS // Comment this out (using // at the start of the line) to disable the endstop pullup resistors
#if DISABLED(ENDSTOPPULLUPS)
  // fine endstop settings: Individual pullups. will be ignored if ENDSTOPPULLUPS is defined
  //#define ENDSTOPPULLUP_XMAX
  //#define ENDSTOPPULLUP_YMAX
  //#define ENDSTOPPULLUP_ZMAX
  //#define ENDSTOPPULLUP_XMIN
  //#define ENDSTOPPULLUP_YMIN
  //#define ENDSTOPPULLUP_ZMIN
  //#define ENDSTOPPULLUP_ZMIN_PROBE
#endif
//#define X_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop.
//#define Y_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop.
//#define Z_MIN_ENDSTOP_INVERTING true  // set to true to invert the logic of the endstop.
//#define X_MAX_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop.
//#define Y_MAX_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop.
//#define Z_MAX_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop.
//#define Z_MIN_PROBE_ENDSTOP_INVERTING true  // set to true to invert the logic of the probe.
#define X_MIN_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop.
#define Y_MIN_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop.
//#define Z_MIN_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop. For stock inductive sensor
#define Z_MIN_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. For IR sensor
#define X_MAX_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop.
#define Y_MAX_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop.
#define Z_MAX_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop.
//#define Z_MIN_PROBE_ENDSTOP_INVERTING true // set to true to invert the logic of the endstop. For stock inductive sensor
#define Z_MIN_PROBE_ENDSTOP_INVERTING false // set to true to invert the logic of the endstop. For IR sensor
// Enable this feature if all enabled endstop pins are interrupt-capable.
// This will remove the need to poll the interrupt pins, saving many CPU cycles.
//#define ENDSTOP_INTERRUPTS_FEATURE
//============================== Movement Settings ============================
// @section motion
 * Default Settings
 * These settings can be reset by M502
 * Note that if EEPROM is enabled, saved values will override these.
 * With this option each E stepper can have its own factors for the
 * following movement settings. If fewer factors are given than the
 * total number of extruders, the last value applies to the rest.
//#define DISTINCT_E_FACTORS
 * Default Axis Steps Per Unit (steps/mm)
 * Override with M92
 *                                      X, Y, Z, E0 [, E1[, E2[, E3[, E4]]]]
//#define DEFAULT_AXIS_STEPS_PER_UNIT   { 80, 80, 398.269957,94.4962144 }
#define DEFAULT_AXIS_STEPS_PER_UNIT   { 80, 80, 400,94.4962144 }
 * Default Max Feed Rate (mm/s)
 * Override with M203
#define DEFAULT_MAX_FEEDRATE          { 200, 200, 5, 25 }
 * Default Max Acceleration (change/s) change = mm/s
 * (Maximum start speed for accelerated moves)
 * Override with M201
#define DEFAULT_MAX_ACCELERATION      { 1200, 1200, 100, 10000 }
 * Default Acceleration (change/s) change = mm/s
 * Override with M204
 *   M204 P    Acceleration
 *   M204 R    Retract Acceleration
 *   M204 T    Travel Acceleration
#define DEFAULT_ACCELERATION          1200    // X, Y, Z and E acceleration for printing moves
#define DEFAULT_RETRACT_ACCELERATION  3000    // E acceleration for retracts
#define DEFAULT_TRAVEL_ACCELERATION   1200    // X, Y, Z acceleration for travel (non printing) moves
 * Default Jerk (mm/s)
 * Override with M205 X Y Z E
 * "Jerk" specifies the minimum speed change that requires acceleration.
 * When changing speed and direction, if the difference is less than the
 * value set here, it may happen instantaneously.
#define DEFAULT_XJERK                 10.0
#define DEFAULT_YJERK                 10.0
#define DEFAULT_ZJERK                  0.4
#define DEFAULT_EJERK                  5.0
//============================= Z Probe Options =============================
// @section probes
// See http://marlinfw.org/configuration/probes.html
 * Z_MIN_PROBE_USES_Z_MIN_ENDSTOP_PIN
 * Enable this option for a probe connected to the Z Min endstop pin.
 * Z_MIN_PROBE_ENDSTOP
 * Enable this option for a probe connected to any pin except Z-Min.
 * (By default Marlin assumes the Z-Max endstop pin.)
 * To use a custom Z Probe pin, set Z_MIN_PROBE_PIN below.
 *  - The simplest option is to use a free endstop connector.
 *  - Use 5V for powered (usually inductive) sensors.
 *  - RAMPS 1.3/1.4 boards may use the 5V, GND, and Aux4->D32 pin:
 *    - For simple switches connect...
 *      - normally-closed switches to GND and D32.
 *      - normally-open switches to 5V and D32.
 * WARNING: Setting the wrong pin may have unexpected and potentially
 * disastrous consequences. Use with caution and do your homework.
 * Probe Type
 * Allen Key Probes, Servo Probes, Z-Sled Probes, FIX_MOUNTED_PROBE, etc.
 * Activate one of these to use Auto Bed Leveling below.
 * The "Manual Probe" provides a means to do "Auto" Bed Leveling without a probe.
 * Use G29 repeatedly, adjusting the Z height at each point with movement commands
 * or (with LCD_BED_LEVELING) the LCD controller.
//#define PROBE_MANUALLY
 * A Fix-Mounted Probe either doesn't deploy or needs manual deployment.
 *   (e.g., an inductive probe or a nozzle-based probe-switch.)
#define FIX_MOUNTED_PROBE
 * Z Servo Probe, such as an endstop switch on a rotating arm.
//#define Z_ENDSTOP_SERVO_NR 0   // Defaults to SERVO 0 connector.
//#define Z_SERVO_ANGLES {70,0}  // Z Servo Deploy and Stow angles
 * The BLTouch probe uses a Hall effect sensor and emulates a servo.
//#define BLTOUCH
#if ENABLED(BLTOUCH)
  //#define BLTOUCH_DELAY 375   // (ms) Enable and increase if needed
#endif
 * Enable one or more of the following if probing seems unreliable.
 * Heaters and/or fans can be disabled during probing to minimize electrical
 * noise. A delay can also be added to allow noise and vibration to settle.
 * These options are most useful for the BLTouch probe, but may also improve
 * readings with inductive probes and piezo sensors.
//#define PROBING_HEATERS_OFF       // Turn heaters off when probing
//#define PROBING_FANS_OFF          // Turn fans off when probing
//#define DELAY_BEFORE_PROBING 200  // (ms) To prevent vibrations from triggering piezo sensors
// A probe that is deployed and stowed with a solenoid pin (SOL1_PIN)
//#define SOLENOID_PROBE
// A sled-mounted probe like those designed by Charles Bell.
//#define Z_PROBE_SLED
//#define SLED_DOCKING_OFFSET 5  // The extra distance the X axis must travel to pickup the sled. 0 should be fine but you can push it further if you'd like.
// For Z_PROBE_ALLEN_KEY see the Delta example configurations.
 *   Z Probe to nozzle (X,Y) offset, relative to (0, 0).
 *   X and Y offsets must be integers.
 *   In the following example the X and Y offsets are both positive:
 *   #define X_PROBE_OFFSET_FROM_EXTRUDER 10
 *   #define Y_PROBE_OFFSET_FROM_EXTRUDER 10
 *      +-- BACK ---+
 *    L |    (+) P  | R <-- probe (20,20)
 *    E |           | I
 *    F | (-) N (+) | G <-- nozzle (10,10)
 *    T |           | H
 *      |    (-)    | T
 *      O-- FRONT --+
 *    (0,0)
// For Diff IR Sensor
#define X_PROBE_OFFSET_FROM_EXTRUDER 9  // X offset: -left  +right  [of the nozzle]
#define Y_PROBE_OFFSET_FROM_EXTRUDER 57  // Y offset: -front +behind [the nozzle]
#define Z_PROBE_OFFSET_FROM_EXTRUDER -1.1   // Z offset: -below +above  [the nozzle]
// For induction probe
//#define X_PROBE_OFFSET_FROM_EXTRUDER 10  // X offset: -left  +right  [of the nozzle]
//#define Y_PROBE_OFFSET_FROM_EXTRUDER 63  // Y offset: -front +behind [the nozzle]
//#define Z_PROBE_OFFSET_FROM_EXTRUDER -0.5   // Z offset: -below +above  [the nozzle]
//#define Y_PROBE_OFFSET_FROM_EXTRUDER 60  // Y offset: -front +behind [the nozzle]
//#define Z_PROBE_OFFSET_FROM_EXTRUDER -1.2   // Z offset: -below +above  [the nozzle]
// X and Y axis travel speed (mm/m) between probes
#define XY_PROBE_SPEED 2000
// Speed for the first approach when double-probing (with PROBE_DOUBLE_TOUCH)
#define Z_PROBE_SPEED_FAST HOMING_FEEDRATE_Z
// Speed for the "accurate" probe of each point
#define Z_PROBE_SPEED_SLOW (Z_PROBE_SPEED_FAST / 2)
// Use double touch for probing
//#define PROBE_DOUBLE_TOUCH
 * Z probes require clearance when deploying, stowing, and moving between
 * probe points to avoid hitting the bed and other hardware.
 * Servo-mounted probes require extra space for the arm to rotate.
 * Inductive probes need space to keep from triggering early.
 * Use these settings to specify the distance (mm) to raise the probe (or
 * lower the bed). The values set here apply over and above any (negative)
 * probe Z Offset set with Z_PROBE_OFFSET_FROM_EXTRUDER, M851, or the LCD.
 * Only integer values >= 1 are valid here.
 * Example: `M851 Z-5` with a CLEARANCE of 4  =>  9mm from bed to nozzle.
 *     But: `M851 Z+1` with a CLEARANCE of 2  =>  2mm from bed to nozzle.
#define Z_CLEARANCE_DEPLOY_PROBE   0  // Z Clearance for Deploy/Stow
#define Z_CLEARANCE_BETWEEN_PROBES  0 // Z Clearance between probe points
// For M851 give a range for adjusting the Z probe offset
#define Z_PROBE_OFFSET_RANGE_MIN -20
#define Z_PROBE_OFFSET_RANGE_MAX 20
// Enable the M48 repeatability test to test probe accuracy
//#define Z_MIN_PROBE_REPEATABILITY_TEST
// For Inverting Stepper Enable Pins (Active Low) use 0, Non Inverting (Active High) use 1
// :{ 0:'Low', 1:'High' }
#define X_ENABLE_ON 0
#define Y_ENABLE_ON 0
#define Z_ENABLE_ON 0
#define E_ENABLE_ON 0 // For all extruders
// Disables axis stepper immediately when it's not being used.
// WARNING: When motors turn off there is a chance of losing position accuracy!
#define DISABLE_X false
#define DISABLE_Y false
#define DISABLE_Z false
// Warn on display about possibly reduced accuracy
//#define DISABLE_REDUCED_ACCURACY_WARNING
#define DISABLE_E false // For all extruders
#define DISABLE_INACTIVE_EXTRUDER true // Keep only the active extruder enabled.
// @section machine
// Invert the stepper direction. Change (or reverse the motor connector) if an axis goes the wrong way.
#define INVERT_X_DIR false
#define INVERT_Y_DIR false
#define INVERT_Z_DIR true
// Enable this option for Toshiba stepper drivers
//#define CONFIG_STEPPERS_TOSHIBA
// For direct drive extruder v9 set to true, for geared extruder set to false.
#define INVERT_E0_DIR false
#define INVERT_E1_DIR false
#define INVERT_E2_DIR false
#define INVERT_E3_DIR false
#define INVERT_E4_DIR false
// @section homing
#define Z_HOMING_HEIGHT 5  // (in mm) Minimal z height before homing (G28) for Z clearance above the bed, clamps, ...
                             // Be sure you have this distance over your Z_MAX_POS in case.
// Direction of endstops when homing; 1=MAX, -1=MIN
// :[-1,1]
#define X_HOME_DIR -1
#define Y_HOME_DIR -1
#define Z_HOME_DIR -1
// @section machine
// The size of the print bed
#define X_BED_SIZE 210
#define Y_BED_SIZE 197  // Bed is really 270, but the height sensor will go off the board at 197, so we don't want to go farther than that
// Travel limits (mm) after homing, corresponding to endstop positions.
#define X_MIN_POS 0
#define Y_MIN_POS 0
#define Z_MIN_POS 0
#define X_MAX_POS X_BED_SIZE
#define Y_MAX_POS Y_BED_SIZE
#define Z_MAX_POS 180
// If enabled, axes won't move below MIN_POS in response to movement commands.
#define MIN_SOFTWARE_ENDSTOPS
// If enabled, axes won't move above MAX_POS in response to movement commands.
#define MAX_SOFTWARE_ENDSTOPS
 * Filament Runout Sensor
 * A mechanical or opto endstop is used to check for the presence of filament.
 * RAMPS-based boards use SERVO3_PIN.
 * For other boards you may need to define FIL_RUNOUT_PIN.
 * By default the firmware assumes HIGH = has filament, LOW = ran out
//#define FILAMENT_RUNOUT_SENSOR
#if ENABLED(FILAMENT_RUNOUT_SENSOR)
  #define FIL_RUNOUT_INVERTING false // set to true to invert the logic of the sensor.
  #define ENDSTOPPULLUP_FIL_RUNOUT // Uncomment to use internal pullup for filament runout pins if the sensor is defined.
  #define FILAMENT_RUNOUT_SCRIPT "M600"
#endif
//=============================== Bed Leveling ==============================
// @section bedlevel
 * Choose one of the options below to enable G29 Bed Leveling. The parameters
 * and behavior of G29 will change depending on your selection.
 *  If using a Probe for Z Homing, enable Z_SAFE_HOMING also!
 * - AUTO_BED_LEVELING_3POINT
 *   Probe 3 arbitrary points on the bed (that aren't collinear)
 *   You specify the XY coordinates of all 3 points.
 *   The result is a single tilted plane. Best for a flat bed.
 * - AUTO_BED_LEVELING_LINEAR
 *   Probe several points in a grid.
 *   You specify the rectangle and the density of sample points.
 * - AUTO_BED_LEVELING_BILINEAR
 *   The result is a mesh, best for large or uneven beds.
 * - AUTO_BED_LEVELING_UBL (Unified Bed Leveling)
 *   A comprehensive bed leveling system combining the features and benefits
 *   of other systems. UBL also includes integrated Mesh Generation, Mesh
 *   Validation and Mesh Editing systems. Currently, UBL is only checked out
 *   for Cartesian Printers. That said, it was primarily designed to correct
 *   poor quality Delta Printers. If you feel adventurous and have a Delta,
 *   please post an issue if something doesn't work correctly. Initially,
 *   you will need to set a reduced bed size so you have a rectangular area
 *   to test on.
 * - MESH_BED_LEVELING
 *   Probe a grid manually
 *   The result is a mesh, suitable for large or uneven beds. (See BILINEAR.)
 *   For machines without a probe, Mesh Bed Leveling provides a method to perform
 *   leveling in steps so you can manually adjust the Z height at each grid-point.
 *   With an LCD controller the process is guided step-by-step.
//#define AUTO_BED_LEVELING_3POINT
//#define AUTO_BED_LEVELING_LINEAR
//#define AUTO_BED_LEVELING_BILINEAR
#define AUTO_BED_LEVELING_UBL
//#define MESH_BED_LEVELING
 * Enable detailed logging of G28, G29, M48, etc.
 * Turn on with the command 'M111 S32'.
 * NOTE: Requires a lot of PROGMEM!
//#define DEBUG_LEVELING_FEATURE
#if ENABLED(MESH_BED_LEVELING) || ENABLED(AUTO_BED_LEVELING_BILINEAR) || ENABLED(AUTO_BED_LEVELING_UBL)
  // Gradually reduce leveling correction until a set height is reached,
  // at which point movement will be level to the machine's XY plane.
  // The height can be set with M420 Z<height>
  #define ENABLE_LEVELING_FADE_HEIGHT
#endif
#if ENABLED(AUTO_BED_LEVELING_LINEAR) || ENABLED(AUTO_BED_LEVELING_BILINEAR)
  // Set the number of grid points per dimension.
  #define GRID_MAX_POINTS_X 4
  #define GRID_MAX_POINTS_Y GRID_MAX_POINTS_X
  // Set the boundaries for probing (where the probe can reach).
  //PJP - You will need to adjust these values to fit your probe location
  //These are my positions for the standard SN04-N sensor using an
  //adjustable mount that can be found on Thingiverse
  //The closer you can get your sensor to the nozzle the better
//  #define LEFT_PROBE_BED_POSITION 10
//  #define RIGHT_PROBE_BED_POSITION 205
//  #define FRONT_PROBE_BED_POSITION 63
//  #define BACK_PROBE_BED_POSITION 245
//  #define LEFT_PROBE_BED_POSITION 15
//  #define RIGHT_PROBE_BED_POSITION 170
//  #define FRONT_PROBE_BED_POSITION 20
//  #define BACK_PROBE_BED_POSITION 170
// Diff IR Sensor
  #define LEFT_PROBE_BED_POSITION 9
  #define RIGHT_PROBE_BED_POSITION 210
  #define FRONT_PROBE_BED_POSITION 71
  #define BACK_PROBE_BED_POSITION 197
  // The Z probe minimum outer margin (to validate G29 parameters).
  #define MIN_PROBE_EDGE 10
  // Probe along the Y axis, advancing X after each column
  //#define PROBE_Y_FIRST
  #if ENABLED(AUTO_BED_LEVELING_BILINEAR)
    // Beyond the probed grid, continue the implied tilt?
    // Default is to maintain the height of the nearest edge.
    //#define EXTRAPOLATE_BEYOND_GRID
    // Experimental Subdivision of the grid by Catmull-Rom method.
    // Synthesizes intermediate points to produce a more detailed mesh.
    //#define ABL_BILINEAR_SUBDIVISION
    #if ENABLED(ABL_BILINEAR_SUBDIVISION)
      // Number of subdivisions between probe points
      #define BILINEAR_SUBDIVISIONS 3
    #endif
  #endif
#elif ENABLED(AUTO_BED_LEVELING_3POINT)
  // 3 arbitrary points to probe.
  // A simple cross-product is used to estimate the plane of the bed.
  #define ABL_PROBE_PT_1_X 15
  #define ABL_PROBE_PT_1_Y 180
  #define ABL_PROBE_PT_2_X 15
  #define ABL_PROBE_PT_2_Y 80
  #define ABL_PROBE_PT_3_X 170
  #define ABL_PROBE_PT_3_Y 80
#elif ENABLED(AUTO_BED_LEVELING_UBL)
  //========================= Unified Bed Leveling ============================
  #define UBL_MESH_INSET 1          // Mesh inset margin on print area
  #define GRID_MAX_POINTS_X 10      // Don't use more than 15 points per axis, implementation limited.
  #define UBL_PROBE_PT_1_X 39       // Probing points for 3-Point leveling of the mesh
  #define UBL_PROBE_PT_1_Y 180
  #define UBL_PROBE_PT_2_X 39
  #define UBL_PROBE_PT_2_Y 80
  #define UBL_PROBE_PT_3_X 180
  #define UBL_PROBE_PT_3_Y 80
  //#define UBL_G26_MESH_VALIDATION // Enable G26 mesh validation
  #define UBL_MESH_EDIT_MOVES_Z     // Sophisticated users prefer no movement of nozzle
#elif ENABLED(MESH_BED_LEVELING)
  //=================================== Mesh ==================================
  // MESH_BED_LEVELING option, Users with a probe should enable one of the AUTO_BED_LEVELING_* options instead.
  #define MESH_INSET 10          // Mesh inset margin on print area
  #define GRID_MAX_POINTS_X 3    // Don't use more than 7 points per axis, implementation limited.
  //#define MESH_G28_REST_ORIGIN // After homing all axes ('G28' or 'G28 XYZ') rest Z at Z_MIN_POS
#endif // BED_LEVELING
 * Use the LCD controller for bed leveling
 * Requires MESH_BED_LEVELING or PROBE_MANUALLY
//#define LCD_BED_LEVELING
#if ENABLED(LCD_BED_LEVELING)
  #define MBL_Z_STEP 0.025    // Step size while manually probing Z axis.
  #define LCD_PROBE_Z_RANGE 4 // Z Range centered on Z_MIN_POS for LCD Z adjustment
  #define LEVEL_BED_CORNERS   // Add an option to move between corners
#endif
 * Commands to execute at the end of G29 probing.
 * Useful to retract or move the Z probe out of the way.
//#define Z_PROBE_END_SCRIPT "G1 Z10 F12000\nG1 X15 Y330\nG1 Z0.5\nG1 Z10"
// @section homing
// The center of the bed is at (X=0, Y=0)
//#define BED_CENTER_AT_0_0
// Manually set the home position. Leave these undefined for automatic settings.
// For DELTA this is the top-center of the Cartesian print volume.
//#define MANUAL_X_HOME_POS 0
//#define MANUAL_Y_HOME_POS 0
//#define MANUAL_Z_HOME_POS 0
// Use "Z Safe Homing" to avoid homing with a Z probe outside the bed area.
// With this feature enabled:
// - Allow Z homing only after X and Y homing AND stepper drivers still enabled.
// - If stepper drivers time out, it will need X and Y homing again before Z homing.
// - Move the Z probe (or nozzle) to a defined XY point before Z Homing when homing all axes (G28).
// - Prevent Z homing when the Z probe is outside bed area.
//  #define Z_SAFE_HOMING_X_POINT X10                   // X point for Z homing when homing all axis (G28).
//  #define Z_SAFE_HOMING_Y_POINT Y10                   // Y point for Z homing when homing all axis (G28).
  #define Z_SAFE_HOMING_X_POINT (((X_MIN_POS + X_MAX_POS) / 2) + X_PROBE_OFFSET_FROM_EXTRUDER)    // X point for Z homing when homing all axis (G28).
  #define Z_SAFE_HOMING_Y_POINT (((Y_MIN_POS + Y_MAX_POS) / 2) + Y_PROBE_OFFSET_FROM_EXTRUDER)    // Y point for Z homing when homing all axis (G28).
#endif
// Homing speeds (mm/m)
#define HOMING_FEEDRATE_XY (50*60)
//PJP - Boosted this up some, was very slow
//#define HOMING_FEEDRATE_Z  (4*60)
#define HOMING_FEEDRATE_Z  (10*60)
//============================= Additional Features ===========================
// @section extras
// EEPROM
// The microcontroller can store settings in the EEPROM, e.g. max velocity...
// M500 - stores parameters in EEPROM
// M501 - reads parameters from EEPROM (if you need reset them after you changed them temporarily).
// M502 - reverts to the default "factory settings".  You still need to store them in EEPROM afterwards if you want to.
#define EEPROM_SETTINGS   // Enable for M500 and M501 commands
//#define DISABLE_M503    // Saves ~2700 bytes of PROGMEM. Disable for release!
#define EEPROM_CHITCHAT   // Give feedback on EEPROM commands. Disable to save PROGMEM.
// Host Keepalive
// When enabled Marlin will send a busy status message to the host
// every couple of seconds when it can't accept commands.
#define HOST_KEEPALIVE_FEATURE      // Disable this if your host doesn't like keepalive messages
#define DEFAULT_KEEPALIVE_INTERVAL 2  // Number of seconds between "busy" messages. Set with M113.
//#define BUSY_WHILE_HEATING            // Some hosts require "busy" messages even during heating
// M100 Free Memory Watcher
//#define M100_FREE_MEMORY_WATCHER // uncomment to add the M100 Free Memory Watcher for debug purpose
// G20/G21 Inch mode support
//#define INCH_MODE_SUPPORT
// M149 Set temperature units support
//#define TEMPERATURE_UNITS_SUPPORT
// Preheat Constants
#define PREHEAT_1_TEMP_HOTEND 200
#define PREHEAT_1_TEMP_BED     30
#define PREHEAT_1_FAN_SPEED     0 // Value from 0 to 255
#define PREHEAT_2_TEMP_HOTEND 250
#define PREHEAT_2_TEMP_BED    90
#define PREHEAT_2_FAN_SPEED     0 // Value from 0 to 255
 * Nozzle Park -- EXPERIMENTAL
 * Park the nozzle at the given XYZ position on idle or G27.
 * The "P" parameter controls the action applied to the Z axis:
 *    P0  (Default) If Z is below park Z raise the nozzle.
 *    P1  Raise the nozzle always to Z-park height.
 *    P2  Raise the nozzle by Z-park amount, limited to Z_MAX_POS.
//#define NOZZLE_PARK_FEATURE
#if ENABLED(NOZZLE_PARK_FEATURE)
  // Specify a park position as { X, Y, Z }
  #define NOZZLE_PARK_POINT { (X_MIN_POS + 10), (Y_MAX_POS - 10), 20 }
#endif
 * Clean Nozzle Feature -- EXPERIMENTAL
 * Adds the G12 command to perform a nozzle cleaning process.
 * Parameters:
 *   P  Pattern
 *   S  Strokes / Repetitions
 *   T  Triangles (P1 only)
 * Patterns:
 *   P0  Straight line (default). This process requires a sponge type material
 *       at a fixed bed location. "S" specifies strokes (i.e. back-forth motions)
 *       between the start / end points.
 *   P1  Zig-zag pattern between (X0, Y0) and (X1, Y1), "T" specifies the
 *       number of zig-zag triangles to do. "S" defines the number of strokes.
 *       Zig-zags are done in whichever is the narrower dimension.
 *       For example, "G12 P1 S1 T3" will execute:
 *         |  (X0, Y1) |     /\        /\        /\     | (X1, Y1)
 *       A |           |   /    \    /    \    /    \   |
 *         |  (X0, Y0) | /        \/        \/        \ | (X1, Y0)
 *                       |________|_________|_________|
 *                           T1        T2        T3
 *   P2  Circular pattern with middle at NOZZLE_CLEAN_CIRCLE_MIDDLE.
 *       "R" specifies the radius. "S" specifies the stroke count.
 *       Before starting, the nozzle moves to NOZZLE_CLEAN_START_POINT.
 *   Caveats: The ending Z should be the same as starting Z.
 * Attention: EXPERIMENTAL. G-code arguments may change.
//#define NOZZLE_CLEAN_FEATURE
#if ENABLED(NOZZLE_CLEAN_FEATURE)
  // Default number of pattern repetitions
  #define NOZZLE_CLEAN_STROKES  12
  // Default number of triangles
  #define NOZZLE_CLEAN_TRIANGLES  3
  // Specify positions as { X, Y, Z }
  #define NOZZLE_CLEAN_START_POINT { 30, 30, (Z_MIN_POS + 1)}
  #define NOZZLE_CLEAN_END_POINT   {100, 60, (Z_MIN_POS + 1)}
  // Circular pattern radius
  #define NOZZLE_CLEAN_CIRCLE_RADIUS 6.5
  // Circular pattern circle fragments number
  #define NOZZLE_CLEAN_CIRCLE_FN 10
  // Middle point of circle
  #define NOZZLE_CLEAN_CIRCLE_MIDDLE NOZZLE_CLEAN_START_POINT
  // Moves the nozzle to the initial position
  #define NOZZLE_CLEAN_GOBACK
#endif
 * Print Job Timer
 * Automatically start and stop the print job timer on M104/M109/M190.
 *   M104 (hotend, no wait) - high temp = none,        low temp = stop timer
 *   M109 (hotend, wait)    - high temp = start timer, low temp = stop timer
 *   M190 (bed, wait)       - high temp = start timer, low temp = none
 * The timer can also be controlled with the following commands:
 *   M75 - Start the print job timer
 *   M76 - Pause the print job timer
 *   M77 - Stop the print job timer
#define PRINTJOB_TIMER_AUTOSTART
 * Print Counter
 * Track statistical data such as:
 *  - Total print jobs
 *  - Total successful print jobs
 *  - Total failed print jobs
 *  - Total time printing
 * View the current statistics with M78.
//#define PRINTCOUNTER
//============================= LCD and SD support ============================
// @section lcd
 * LCD LANGUAGE
 * Select the language to display on the LCD. These languages are available:
 *    en, an, bg, ca, cn, cz, cz_utf8, de, el, el-gr, es, eu, fi, fr, gl, hr,
 *    it, kana, kana_utf8, nl, pl, pt, pt_utf8, pt-br, pt-br_utf8, ru, sk_utf8,
 *    tr, uk, zh_CN, zh_TW, test
 * :{ 'en':'English', 'an':'Aragonese', 'bg':'Bulgarian', 'ca':'Catalan', 'cn':'Chinese', 'cz':'Czech', 'cz_utf8':'Czech (UTF8)', 'de':'German', 'el':'Greek', 'el-gr':'Greek (Greece)', 'es':'Spanish', 'eu':'Basque-Euskera', 'fi':'Finnish', 'fr':'French', 'gl':'Galician', 'hr':'Croatian', 'it':'Italian', 'kana':'Japanese', 'kana_utf8':'Japanese (UTF8)', 'nl':'Dutch', 'pl':'Polish', 'pt':'Portuguese', 'pt-br':'Portuguese (Brazilian)', 'pt-br_utf8':'Portuguese (Brazilian UTF8)', 'pt_utf8':'Portuguese (UTF8)', 'ru':'Russian', 'sk_utf8':'Slovak (UTF8)', 'tr':'Turkish', 'uk':'Ukrainian', 'zh_CN':'Chinese (Simplified)', 'zh_TW':'Chinese (Taiwan)', test':'TEST' }
#define LCD_LANGUAGE en
 * LCD Character Set
 * Note: This option is NOT applicable to Graphical Displays.
 * All character-based LCDs provide ASCII plus one of these
 * language extensions:
 *  - JAPANESE ... the most common
 *  - WESTERN  ... with more accented characters
 *  - CYRILLIC ... for the Russian language
 * To determine the language extension installed on your controller:
 *  - Compile and upload with LCD_LANGUAGE set to 'test'
 *  - Click the controller to view the LCD menu
 *  - The LCD will display Japanese, Western, or Cyrillic text
 * See https://github.com/MarlinFirmware/Marlin/wiki/LCD-Language
 * :['JAPANESE', 'WESTERN', 'CYRILLIC']
#define DISPLAY_CHARSET_HD44780 JAPANESE
 * LCD TYPE
 * Enable ULTRA_LCD for a 16x2, 16x4, 20x2, or 20x4 character-based LCD.
 * Enable DOGLCD for a 128x64 (ST7565R) Full Graphical Display.
 * (These options will be enabled automatically for most displays.)
 * IMPORTANT: The U8glib library is required for Full Graphic Display!
 *            https://github.com/olikraus/U8glib_Arduino
#define ULTRA_LCD // Character based
//#define DOGLCD      // Full graphics display
 * SD CARD
 * SD Card support is disabled by default. If your controller has an SD slot,
 * you must uncomment the following option or it won't work.
#define SDSUPPORT
 * SD CARD: SPI SPEED
 * Enable one of the following items for a slower SPI transfer speed.
 * This may be required to resolve "volume init" errors.
//#define SPI_SPEED SPI_HALF_SPEED
//#define SPI_SPEED SPI_QUARTER_SPEED
//#define SPI_SPEED SPI_EIGHTH_SPEED
 * SD CARD: ENABLE CRC
 * Use CRC checks and retries on the SD communication.
#define SD_CHECK_AND_RETRY
// ENCODER SETTINGS
// This option overrides the default number of encoder pulses needed to
// produce one step. Should be increased for high-resolution encoders.
#define ENCODER_PULSES_PER_STEP 2
// Use this option to override the number of step signals required to
// move between next/prev menu items.
#define ENCODER_STEPS_PER_MENU_ITEM 2
 * Encoder Direction Options
 * Test your encoder's behavior first with both options disabled.
 *  Reversed Value Edit and Menu Nav? Enable REVERSE_ENCODER_DIRECTION.
 *  Reversed Menu Navigation only?    Enable REVERSE_MENU_DIRECTION.
 *  Reversed Value Editing only?      Enable BOTH options.
// This option reverses the encoder direction everywhere.
//  Set this option if CLOCKWISE causes values to DECREASE
//#define REVERSE_ENCODER_DIRECTION
// This option reverses the encoder direction for navigating LCD menus.
//  If CLOCKWISE normally moves DOWN this makes it go UP.
//  If CLOCKWISE normally moves UP this makes it go DOWN.
//#define REVERSE_MENU_DIRECTION
// Individual Axis Homing
// Add individual axis homing items (Home X, Home Y, and Home Z) to the LCD menu.
// SPEAKER/BUZZER
// If you have a speaker that can produce tones, enable it here.
// By default Marlin assumes you have a buzzer with a fixed frequency.
#define SPEAKER
// The duration and frequency for the UI feedback sound.
// Set these to 0 to disable audio feedback in the LCD menus.
// Note: Test audio output with the G-Code:
//  M300 S<frequency Hz> P<duration ms>
#define LCD_FEEDBACK_FREQUENCY_DURATION_MS 250
#define LCD_FEEDBACK_FREQUENCY_HZ 500
// CONTROLLER TYPE: Standard
// Marlin supports a wide variety of controllers.
// Enable one of the following options to specify your controller.
// ULTIMAKER Controller.
//#define ULTIMAKERCONTROLLER
// ULTIPANEL as seen on Thingiverse.
//#define ULTIPANEL
// PanelOne from T3P3 (via RAMPS 1.4 AUX2/AUX3)
// http://reprap.org/wiki/PanelOne
//#define PANEL_ONE
// MaKr3d Makr-Panel with graphic controller and SD support.
// http://reprap.org/wiki/MaKr3d_MaKrPanel
//#define MAKRPANEL
// ReprapWorld Graphical LCD
// https://reprapworld.com/?products_details&products_id/1218
//#define REPRAPWORLD_GRAPHICAL_LCD
// Activate one of these if you have a Panucatt Devices
// Viki 2.0 or mini Viki with Graphic LCD
// http://panucatt.com
//#define VIKI2
//#define miniVIKI
// Adafruit ST7565 Full Graphic Controller.
// https://github.com/eboston/Adafruit-ST7565-Full-Graphic-Controller/
//#define ELB_FULL_GRAPHIC_CONTROLLER
// RepRapDiscount Smart Controller.
// http://reprap.org/wiki/RepRapDiscount_Smart_Controller
// Note: Usually sold with a white PCB.
// GADGETS3D G3D LCD/SD Controller
// http://reprap.org/wiki/RAMPS_1.3/1.4_GADGETS3D_Shield_with_Panel
// Note: Usually sold with a blue PCB.
//#define G3D_PANEL
// RepRapDiscount FULL GRAPHIC Smart Controller
// http://reprap.org/wiki/RepRapDiscount_Full_Graphic_Smart_Controller
//#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
// MakerLab Mini Panel with graphic
// controller and SD support - http://reprap.org/wiki/Mini_panel
//#define MINIPANEL
// RepRapWorld REPRAPWORLD_KEYPAD v1.1
// http://reprapworld.com/?products_details&products_id=202&cPath=1591_1626
// REPRAPWORLD_KEYPAD_MOVE_STEP sets how much should the robot move when a key
// is pressed, a value of 10.0 means 10mm per click.
//#define REPRAPWORLD_KEYPAD
//#define REPRAPWORLD_KEYPAD_MOVE_STEP 1.0
// RigidBot Panel V1.0
// http://www.inventapart.com/
//#define RIGIDBOT_PANEL
// BQ LCD Smart Controller shipped by
// default with the BQ Hephestos 2 and Witbox 2.
//#define BQ_LCD_SMART_CONTROLLER
// Cartesio UI
// http://mauk.cc/webshop/cartesio-shop/electronics/user-interface
//#define CARTESIO_UI
// ANET_10 Controller supported displays.
//#define ANET_KEYPAD_LCD         // Requires ADC_KEYPAD_PIN to be assigned to an analog pin.
                                  // This LCD is known to be susceptible to electrical interference
                                  // which scrambles the display.  Pressing any button clears it up.
//#define ANET_FULL_GRAPHICS_LCD  // Anet 128x64 full graphics lcd with rotary encoder as used on Anet A6
                                  // A clone of the RepRapDiscount full graphics display but with
                                  // different pins/wiring (see pins_ANET_10.h).
// LCD for Melzi Card with Graphical LCD
//#define LCD_FOR_MELZI
// CONTROLLER TYPE: I2C
// Note: These controllers require the installation of Arduino's LiquidCrystal_I2C
// library. For more info: https://github.com/kiyoshigawa/LiquidCrystal_I2C
// Elefu RA Board Control Panel
// http://www.elefu.com/index.php?route=product/product&product_id=53
//#define RA_CONTROL_PANEL
// Sainsmart YW Robot (LCM1602) LCD Display
// Note: This controller requires F.Malpartida's LiquidCrystal_I2C library
// https://bitbucket.org/fmalpartida/new-liquidcrystal/wiki/Home
//#define LCD_I2C_SAINSMART_YWROBOT
// Generic LCM1602 LCD adapter
//#define LCM1602
// PANELOLU2 LCD with status LEDs,
// separate encoder and click inputs.
// Note: This controller requires Arduino's LiquidTWI2 library v1.2.3 or later.
// For more info: https://github.com/lincomatic/LiquidTWI2
// Note: The PANELOLU2 encoder click input can either be directly connected to
// a pin (if BTN_ENC defined to != -1) or read through I2C (when BTN_ENC == -1).
//#define LCD_I2C_PANELOLU2
// Panucatt VIKI LCD with status LEDs,
// integrated click & L/R/U/D buttons, separate encoder inputs.
//#define LCD_I2C_VIKI
// SSD1306 OLED full graphics generic display
//#define U8GLIB_SSD1306
// SAV OLEd LCD module support using either SSD1306 or SH1106 based LCD modules
//#define SAV_3DGLCD
#if ENABLED(SAV_3DGLCD)
  #define U8GLIB_SH1106
#endif
// CONTROLLER TYPE: Shift register panels
// 2 wire Non-latching LCD SR from https://goo.gl/aJJ4sH
// LCD configuration: http://reprap.org/wiki/SAV_3D_LCD
//#define SAV_3DLCD
// TinyBoy2 128x64 OLED / Encoder Panel
//#define OLED_PANEL_TINYBOY2
//=============================== Extra Features ==============================
// @section extras
// Increase the FAN PWM frequency. Removes the PWM noise but increases heating in the FET/Arduino
//#define FAST_PWM_FAN
// Use software PWM to drive the fan, as for the heaters. This uses a very low frequency
// which is not as annoying as with the hardware PWM. On the other hand, if this frequency
// is too low, you should also increment SOFT_PWM_SCALE.
//#define FAN_SOFT_PWM
// Incrementing this by 1 will double the software PWM frequency,
// affecting heaters, and the fan if FAN_SOFT_PWM is enabled.
// However, control resolution will be halved for each increment;
// at zero value, there are 128 effective control positions.
#define SOFT_PWM_SCALE 0
// If SOFT_PWM_SCALE is set to a value higher than 0, dithering can
// be used to mitigate the associated resolution loss. If enabled,
// some of the PWM cycles are stretched so on average the desired
// duty cycle is attained.
//#define SOFT_PWM_DITHER
// Temperature status LEDs that display the hotend and bed temperature.
// If all hotends, bed temperature, and target temperature are under 54C
// then the BLUE led is on. Otherwise the RED led is on. (1C hysteresis)
//#define TEMP_STAT_LEDS
// M240  Triggers a camera by emulating a Canon RC-1 Remote
// Data from: http://www.doc-diy.net/photo/rc-1_hacked/
//#define PHOTOGRAPH_PIN     23
// SkeinForge sends the wrong arc g-codes when using Arc Point as fillet procedure
//#define SF_ARC_FIX
// Support for the BariCUDA Paste Extruder
//#define BARICUDA
// Support for BlinkM/CyzRgb
//#define BLINKM
// Support for PCA9632 PWM LED driver
//#define PCA9632
 * RGB LED / LED Strip Control
 * Enable support for an RGB LED connected to 5V digital pins, or
 * an RGB Strip connected to MOSFETs controlled by digital pins.
 * Adds the M150 command to set the LED (or LED strip) color.
 * If pins are PWM capable (e.g., 4, 5, 6, 11) then a range of
 * luminance values can be set from 0 to 255.
 * *** CAUTION ***
 *  LED Strips require a MOFSET Chip between PWM lines and LEDs,
 *  as the Arduino cannot handle the current the LEDs will require.
 *  Failure to follow this precaution can destroy your Arduino!
 * *** CAUTION ***
//#define RGB_LED
//#define RGBW_LED
#if ENABLED(RGB_LED) || ENABLED(RGBW_LED)
  #define RGB_LED_R_PIN 34
  #define RGB_LED_G_PIN 43
  #define RGB_LED_B_PIN 35
  #define RGB_LED_W_PIN -1
#endif
// Support for Adafruit Neopixel LED driver
//#define NEOPIXEL_RGBW_LED
#if ENABLED(NEOPIXEL_RGBW_LED)
  #define NEOPIXEL_PIN    4       // D4 (EXP2-5 on Printrboard)
  #define NEOPIXEL_PIXELS 3
  //#define NEOPIXEL_STARTUP_TEST // Cycle through colors at startup
#endif
 * Printer Event LEDs
 * During printing, the LEDs will reflect the printer status:
 *  - Gradually change from blue to violet as the heated bed gets to target temp
 *  - Gradually change from violet to red as the hotend gets to temperature
 *  - Change to white to illuminate work surface
 *  - Change to green once print has finished
 *  - Turn off after the print has finished and the user has pushed a button
#if ENABLED(BLINKM) || ENABLED(RGB_LED) || ENABLED(RGBW_LED) || ENABLED(PCA9632) || ENABLED(NEOPIXEL_RGBW_LED)
  #define PRINTER_EVENT_LEDS
#endif
* R/C SERVO support
* Sponsored by TrinityLabs, Reworked by codexmas
// Number of servos
// If you select a configuration below, this will receive a default value and does not need to be set manually
// set it manually if you have more servos than extruders and wish to manually control some
// leaving it undefined or defining as 0 will disable the servo subsystem
// If unsure, leave commented / disabled
//#define NUM_SERVOS 3 // Servo index starts with 0 for M280 command
// Delay (in milliseconds) before the next move will start, to give the servo time to reach its target angle.
// 300ms is a good value but you can try less delay.
// If the servo can't reach the requested position, increase it.
//#define SERVO_DELAY { 300 }
// Servo deactivation
// With this option servos are powered only during movement, then turned off to prevent jitter.
//#define DEACTIVATE_SERVOS_AFTER_MOVE
 * Filament Width Sensor
 * Measures the filament width in real-time and adjusts
 * flow rate to compensate for any irregularities.
 * Also allows the measured filament diameter to set the
 * extrusion rate, so the slicer only has to specify the
 * volume.
 * Only a single extruder is supported at this time.
 *  34 RAMPS_14    : Analog input 5 on the AUX2 connector
 *  81 PRINTRBOARD : Analog input 2 on the Exp1 connector (version B,C,D,E)
 * 301 RAMBO       : Analog input 3
 * Note: May require analog pins to be defined for other boards.
//#define FILAMENT_WIDTH_SENSOR
#define DEFAULT_NOMINAL_FILAMENT_DIA 1.75   // (mm) Diameter of the filament generally used (3.0 or 1.75mm), also used in the slicer. Used to validate sensor reading.
#if ENABLED(FILAMENT_WIDTH_SENSOR)
  #define FILAMENT_SENSOR_EXTRUDER_NUM 0    // Index of the extruder that has the filament sensor (0,1,2,3)
  #define MEASUREMENT_DELAY_CM        14    // (cm) The distance from the filament sensor to the melting chamber
  #define MEASURED_UPPER_LIMIT         3.30 // (mm) Upper limit used to validate sensor reading
  #define MEASURED_LOWER_LIMIT         1.90 // (mm) Lower limit used to validate sensor reading
  #define MAX_MEASUREMENT_DELAY       20    // (bytes) Buffer size for stored measurements (1 byte per cm). Must be larger than MEASUREMENT_DELAY_CM.
  #define DEFAULT_MEASURED_FILAMENT_DIA DEFAULT_NOMINAL_FILAMENT_DIA // Set measured to nominal initially
  // Display filament width on the LCD status line. Status messages will expire after 5 seconds.
  //#define FILAMENT_LCD_DISPLAY
#endif
#endif // CONFIGURATION_H
kgrigio
3D Printer(s): HICTOP 3DP-11-ATL
Re: Updating Stock HICTOP 3DP-11-ATL to Latest Marlin and Changing Bed Leveling Sensor
Post by kgrigio »
Here is a link to thingiverse where I show my IR sensor mount
https://www.thingiverse.com/thing:2700601/#files
Looks cool. I may have to get one for my 3DP-17. Was thinking of going with the BLTouch, but this just looks cool.
Chaco
Post by Chaco »
do you have a link to where u got that sensor at?
