Hi to all.
I have Ender 3 3D printer.
Please is there somone know how to preheat printer on my values which I want withot anyoing scrooling wheel!?
Reason: Every time I must going to adjust-scroll one wheel for Bad, and again scrool for Nozzle That take me about 2 minutes for that.
I want preheat automatic on: Bad: 110, Nozzle: 240.
There is option "Preheat ABS" in the menu, but default value are not set which I want.
So, is there some script or something which I can change 'Preheat ABS' settings, or maybe you know other way to preheat printer with less anyoings cliks (and scrools) manually?
Preheat
Re: Preheat
I use a raspberry Pi running OctoPrint.
I can preset my settings and with one click send to the 3D Printer.
Re: Preheat
Can I just connect printer with PC without external stuff (like arduino, raspberry etc.)?Roberts_Clif wrote: ↑December 27th, 2019, 1:42 pm I use a raspberry Pi running OctoPrint.
I was connected my laptop but Cura slicer not not recognize printer!
Re: Preheat
You can use a USB cable to connect your slicer to your 3D Printer and have Cura send the data required.
My 3D Printers are quite some distance from my Computer and a USB cable is not applicable.
Re: Preheat
I didn't connect on laptop, but I connect on PC. It's working. Thanks.
