Your modal is not manifold - error message
sapirmash
Post by sapirmash »
Hello,
When I added my STL file to Cura I got this error message:
And here’s how my modal looks like:
Attached my STL file
T-02 (8).stl
(5.83 MiB) Downloaded 479 times
Is there a way to fix it?
Thanks!
Re: Your modal is not manifold - error message
I tried to open this on my Cura and it was gigantic. I used my Anycubic Chiron profile which is a 450 x 450 x 500 bed volume
I opened and in the same happened had to scale down from 100 % to 25.4% still was over my bed size so scaled the Z- to my max height 190mm.
I sliced the model while it was laying on its side at 25.4% two oval shaped orbs showed the lower third of the model and the top third.
For some reason the middle section was not there.\
sapirmash
Post by sapirmash »
Thanks!
I’ll fix the file size.
When I resized and sliced it, it looks like this:
Regarding the error message is it related to the top section? Where my Vase is open?
Do not have an answer your last question.
