im trying to get edit a sliced file to the level of single pixels, inserting pauses and z axis control. does any one know how to do so? i cant find a proper program to edit this type of file.
the end goal is to get a printer to print only a part of a layer then pause lift the bed then change tanks and resume the print in order to get a multi matrial layers in a print
editing ctb file
Re: editing ctb file
I was wondering if you could pause it manually, if you want to stop in the middle that would be 50%.
You would also need to clean the print as you would have the original resin on the print and it would mix with the new colour as soon as it starts to print again.
