Crappppp Ultimaker 2+ feeder
reibuehl wrote:For PLA this is really strange - especially with such small objects like the robot. I always use 60°C for PLA - often without glue, sometimes with glue - but don't see such warping. But I also haven't used Ultimaker PLA in a long time. Have you checked the bed to nozzle distance recently? I had bad bed adhesion in the past when I didn't level the bed after a nozzle change.
Indeed I never go beyond 60C without glue or anything, just a very clean glass and OFC calibration calibration calibration.
UM2 Automagic calibration assumes 0.1 gap while doing it. So to force it to squish to the bed use a 0.05-0.08 gauge feller.
Also check your fan speed,
Try 50'c for the bed, and 0 fan speed for the 1st layer at 0.2mm thickness.
Then increase the fans over the next 5mm to full.
Dim3nsioneer
Post by Dim3nsioneer »
LePaul, Have you checked if all scres the bed pcb is mounted on the platform with are completely sunk into the pcb? As it is a refurbished UM2+ one has to check for UM2 problems as well.
Yes bed is fine. Note the skirt shows flattened filament
Quite a riddle!
Dim3nsioneer
Yes, levelling can be fine but if only one of those screws is protruding a bit this could result in a 'cold' spot on the glass. And then goes the adhesion. This was quite often an issue with the earlier UM2s.
Good point. I'll inspect it
I'm starting to think it might be the filament.
I need to do some tests with the remaining ColorFabb material and see how that sticks
IMO I always had bad experiences with silver plas from formfutura (horrible) and um (less but still). I suppose makes sense that something with extra shiny particles cools slower.
So...since the filament temps are controlled in the Ulticontroller/display on the UM2...if you wanted to run something like nGen, how to you program the temp into the machine....since it seems absent on Cura
I suppose tou can make a new material profile? Or um2 doesn't have that?
I don't know....Let me move that question to the nGen filament area
LePaul wrote:I don't know....Let me move that question to the nGen filament area
Kind of found my answer...
https://ultimaker.com/en/resources/2098 ... aker2-plus
I think I'll put in the suggested temps and fan settings, leaving the retraction stuff to Cura
Edited the MATERIAL.TXT file and used 230C for nozzle, 80C for bed and 50% fan. I also used their 45 mm/sex retract speed and 4.5 mm distance
Trying a robot print with nGen. You can see it looks good so far. And you can hear the retractions at work
I think I like nGen after all
Titus
Post by Titus »
Nice Paul! It's such a shame you keep running into troubles. But that is a sweet looking ultibot. Just the cooling of the right antenna seems to be off, but overhangs are sweet!
