Got myself a Hictop 3DP11 and i asked Hictop if they could send me the latest firmware and they sent me "Marlin_3DP08_3DP11_398.cpp.hex" i then used cura to upload it to my printer via USB.
i use simply3d for slicer.
nozzle diameter: 0.40
extrusion multiplyer: 1.00
extrusion width - manual: 0.40
first layer hight and width 100%
first layer speed 50%
default print speed 50mm/s
Everything seems to be good but the steps are a bit off in the printer i think.
when i print a 20 x 20 x 10mm test cube the results of the printed cube are 19.99 x 20.01 x 9.68
all my prints have a elephant foot and the layers look squashed so i tried changing the zsteps in the printer lcd screen from 0398.0 to 0403.0 and this seemed to make the dimensions better but every time i turn the printer off it reverts back the the 0398.0 settings.
I don't have any plans to make precision parts, but would like to know how to set the zsteps in the printer so they stay as i set them, also would be nice to loose that elephant foot because its far to wide even with first layer width 60% and hight 60% i still get a elephant foot .
and the last thing is the levelling, if i level the bed from the home axis then print, the print starts higher than i set it from the home axis by about 1mm resulting in curling up filament onto the tip and not printing to the bed, So i level it by starting a print then turning the printer off just as its started extruding then i level the bed and turn it on again ready to go.
would be nice to get some help on the above problems
TIA
