And I've simply made hitting the Maintenance Menu, hit Heat up Build Plate, select 61, then select Move Material a regular habit
I've been chatting with one of the gents from Ultimaker about it and even done a firmware upgrade to my machine, to see if that did anything.
Not really.
I had a 3 hour print finish. Once everything had cooled down, I removed the print and started another one. I could see the filament move in he Bowden but not enough was making it to the hot end. I left it alone and since i had a lot of skirt lines on the print, it eventually put out a few dots, then eventually (by the second pass) material had begun to flow.
But that's not normal. There should be a healthy blob under the print head at the start of the print, the print head moves away and off it goes.
Since Ultimaker sent me two Ultimaker 2+ Extended's (and two Ultimaker 3's) for an upcoming comic-con, I have had a chance to try this out on the UM2+E's on hand
They do the same thing.
I had them doing a print last night and when done, I powered them off. This morning, I had each of the UM2+E's start a new print. Both had the same issue extruding material at the start of the print.
Maybe I'm not crazy
Anyone else notice the same with their UM2's?
