Zero Gravity Direct Drive Extruder
Re: Zero Gravity Direct Drive Extruder
Umm maybe I didn't understood. Photo? I'm too sleepy
Post by nilrog »
No, it's the spacer between the "yaw" and the part where you screw the stepper into. I tried to reference them above by their name in the zip-file ;)
Post by nilrog »
Maybe photo later today :p
Post by nilrog »
It's one of the parts named "FLEX" that is part of the Nema17 zip even though you need it for the Bondtech.
Can you check with the full stl assembly ? I don't get it. Sorry I'm really dense atm
Post by nilrog »
NP, will check it tonight :)
I've only used the photos and files as base for my assembly so far. And for the temp PLA parts it was ok. But now when I'm replacing them with flexible parts it gets a bit confusing :P
Post by nilrog »
Ok, I was probably a bit confused, i'm down with a flu this weekend :( (the "man-cold" version :lol: )
I was referring to this yellow piece where the screws to the motor holder goes through:
And I though that the "Motor support damper-FLEX.stl" from the NEMA17 zip was this one...but I now see that it is the one that will hold the NEMA17 motor instead.
So I guess that the yellow part is this one, "Motor tilt spacer support-MEDQ.stl"?
It's slightly confusing since all the parts needed for the Bondtech geared version is not in the Bondtech package...while for the NEMA17 all files are there ;)
Anyway, I think i'm back on track now and will soon finish the Bondtech-Short version :)
(Although i'm still very impressed with the all-PLA version. I have had zero problems with it...and now I can easily print #filaflex with 40mm/s at 0.15 :) )
That yellow part is solid, not flex.
