Slicers that use the ARC length formula function
A general question about slicers.
Does anyone know what Slicers allow uses of the ARC length formula function.
As the function speed up many 3D Prints it would be handy to know which Slicers allow ARC length formula.
It appears I am asking the wrong question.
"The model you export has that pattern, not the slicer. You need to increase the export resolution of you drafting tool (AutoCAD, Fusion360, TinkerCAD, etc.) ..."
I found this GCodeArcOptimiser
Though as I continued to research found that this will not even work correctly.
