Cura Post
Cura Post
@LePaul I read a post you made on Cura and was curious of how you think the function works with newer Cura ver...
Re: Cura Post
Laying flat? Yeah.... I never really got an answer
Re: Cura Post
Did not see one either, found others with the same opinion an no solution was posted...
How do you quickly and easily get an object to lay flat in Cura? It seems much more difficult than in past versions of the software.
And one that put this option forth.The lay flat is horribly implemented. It's fairly slow and doesn't even always give the best solution.
I never this existed.If lay flat doesn't work then you can hold shift and do smaller rotational adjustments.
