Cura Post
Posted: December 14th, 2020, 10:02 am
@LePaul I read a post you made on Cura and was curious of how you think the function works with newer Cura ver...
How do you quickly and easily get an object to lay flat in Cura? It seems much more difficult than in past versions of the software.
And one that put this option forth.The lay flat is horribly implemented. It's fairly slow and doesn't even always give the best solution.
I never this existed.If lay flat doesn't work then you can hold shift and do smaller rotational adjustments.
