Hi there! If anyone is having issues with the inductive Z-axis sensor, I have a good solution for the issue of a glass plate on the bed.
Instead of using the sensor to detect the bed, use it to detect the X-axis bottom smooth rod.
I removed the sensor from the mount and used electrical tape to attach it to the vertical aluminum frame on the left, facing upwards. It was then just a matter of finding the right height to fix it at to detect the bottom smooth metal rod on the X-axis, as shown in the picture.
Hope this helps anyone with a glass plate.
Mike
Z-axis sensor issue solution
Jump to
- Announcements
- ↳ News and Announcements
- 3D Printers
- ↳ General / RepRap Printers
- ↳ HICTOP RepRap Prusa I3
- ↳ Hardware Modifications
- ↳ General Questions
- ↳ Large Scale 3D Printers
- ↳ Tevo brand 3D Printers
- ↳ Resin 3D Printers
- ↳ Micro 3D Printers
- Ultimaker Printers
- ↳ Ultimaker S5
- ↳ General Discussion
- ↳ Special brand filaments
- Getting better prints!
- ↳ Help me fix this print!
- Software & Electronics
- ↳ Slicers and CAD Software
- ↳ Cura
- ↳ Simplify 3D
- ↳ Other Slicing programs
- ↳ Slic3r
- ↳ Electronics
- ↳ Firmware
- ↳ Firmware
- General
- ↳ Off Topics!
- ↳ The MarketPlace
- Modders Kiosk
