Setting Z-value for HOME HOME position ????
ksor
3D Printer(s): CR10s PRO
Post by ksor »
I have a
CR 10s PRO ver 2
Firmware Tiny Machines
TM3D 10sPro V2
DW 7.4.6
I've installed a BLTouch and I think I need to adjust the zero-point for the Z axis.
It driving me crazy - when I press the HOME button it smaches the extruder into the bed !
I have adjusted the gantry to the heigth of that plastic peace delivered with the printer.
Even the leveling video fra Tiny Machines is not very specific on how to do it - he has NOT at any time the AUTO-leveling
button turned ON - and I CAN'T get it turned ON on my printer -it just flpis OFF when I press it.
DON'T just link me to all the leveling videos out the - NONE of them is explaining how to RESET or SET the HOME Z-value !
Instead, tell me how it's done.
Re: Setting Z-value for HOME HOME position ????
CR-10s PRO V2 with a BLTouch
Calibrate the Z-offset by heating the bed, placing a feeler gauge under nozzle.
Use LCD to lower the nozzle until slight drag is felt record this as Z-Offset.
Goto "Prepare > Move Axes > Move Z" and use Z-Offset value to set the nozzle height.
Save the setting using "Store Settings"
ksor
Post by ksor »
Please tell me WHERE he SRORES the new Z-value ... I can't find it !
If you go through that video, you'll see the Z offset is shown just under where it say CREALTY
ksor
Post by ksor »
I can see that but that's NOT what I'm saying.
I say, it's NOT clear WHERE in the vidio he STORES the value.
If it's stored every time he change it
OR
did he forget to tell when he presses ... yeah, presses what button ?
