Cura gaps in prints
Rotton1211
3D Printer(s): Ender 5
Cura gaps in prints
Post by Rotton1211 »
Hello,
I am using an Ender-5 and Cura 5. I never really had problems with my prints, but recently I have gaps in all of them in the x-y direction. Even in between of the walls are gaps now. Does anyone have an Idea how to fix it? The outer Dimensions of the parts are spot on so I dont want to increase the flow rate. And its not just the first layer.
Re: Cura gaps in prints
It could be a value applied to the Cura Overlap.
Post your Cura profile
Rotton1211
Ok so what do you recommend changing?
Here are the printer Settings.
Cura Settings Export12.pdf
(155.41 KiB) Downloaded 735 times
Try changing these
Line Width 0.45 mm
Wall Line Width 0.45 mm
Outer Wall Line Width 0.45 mm
Inner Wall(s) Line Width 0.45 mm
Top/Bottom Line Width 0.45 mm
Infill Line Width 0.45 mm
Skirt/Brim Line Width 0.45 mm
Support Line Width 0.45 mm
Based on the skirt line, your z offset looks good
You've already calculated your slicer flow settings?
https://teachingtechyt.github.io/calibration.html#flow
Return to “Cura”
